99 gsr tranny need help ASAP...
Old Jan 20, 2007 | 07:49 AM
Lscivic1999's Avatar
Default 99 gsr tranny need help ASAP...
I have a 99 gsr tranny on my ls motor,now everytime am drivin the car on the highway and I shift 5th gear the tranny will run and then put it back to neutral, sometimes it does often like 2 or 3 times in a mile sometimes it doesn't do it in 10 miles.....I have no idea what could be causing the problem...any ideas or suggestion are needed plz let me know..
Old Jan 20, 2007 | 08:00 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: 99 gsr tranny need help ASAP... (Lscivic1999)
It sounds like the shift linkage is not positioned correctly.
Old Jan 20, 2007 | 08:20 AM
Default Re: 99 gsr tranny need help ASAP... (Dogginator)
I have the swap over a year now and it has never happen'd, everything was working fine for more than a year and all the other gears works fine but they are starting to feel a lil be hard when I shift to any gear ...do you still think it could be the shift linkage??
Old Jan 20, 2007 | 11:58 AM
Dogginator's Avatar
Daisy... Daisy...
You could have a mount going bad. It it equally difficult to engages second and fourth gear?
Old Jan 20, 2007 | 12:25 PM
All the gears engages fine even the fith one,it would just come back to neutral sometimes
Old Jan 20, 2007 | 12:35 PM
CleanLikeJdm's Avatar
Hype-R Stalker
If it's popping back into neutral, it could be low on trans fluid,
mine did the exact same thing with 5th gear.
Old Jan 20, 2007 | 04:45 PM
mr_ek9's Avatar
Default Re: 99 gsr tranny need help ASAP... (CleanLikeJdm)
I'm pretty sure it's low on trans fluid. Thats what mine did put tranny fluid didn't pop out anymore.
Old Jan 21, 2007 | 10:21 AM
Default Re: 99 gsr tranny need help ASAP... (mr_ek9)
All right...ima put some oil in the tranny ..asap...bcuz that shyt was driving me crazy....thank u guyz.
Old Jan 21, 2007 | 11:21 AM
Hype-R Stalker
You might wanna figure out too if it's actually leaking,
because if you get Too low, then your trans is cooked.
Old Jan 21, 2007 | 11:29 AM
Damn r u serious I just check'd it and it look'd like its been having a leak..so if it is really low fluid you think the tranny may be done?
Old Jan 21, 2007 | 02:26 PM
Hype-R Stalker
You would know if it went because it would lock up,
mine had a small leak inside the bell housing, and locked up two days later.
Old Jan 21, 2007 | 02:35 PM
Oo0O damn mines isn't locking up yet I'll have to take care of that before I have 2 get $400 outta mah pocket for another tranny......
slomotn
Jul 18, 2011 04:39 AM
wallabee32
Feb 13, 2008 01:44 AM
akirab16
Oct 10, 2004 03:35 PM
drewlee
Jan 8, 2004 09:36 AM
ncVTEC1313
Oct 14, 2003 04:52 AM
