NO VTEC...MOTOR CUTS OUT AT 5000 ROM Could u help
Old Jan 19, 2007 | 03:43 PM
Stephdavis18's Avatar
Default NO VTEC...MOTOR CUTS OUT AT 5000 ROM Could u help
Like it says...no vtec and motor cuts out at 5k check engine light is on and it throws a vtec oil pressure switch code. Is there a way to bypass it. Ive heard there is but the diagram I found is from a 0bd1 motor. I have a obd2 b18c1 in a ek9 Bone stock swap.
Old Jan 20, 2007 | 08:14 AM
95 integra's Avatar
Default Re: NO VTEC...MOTOR CUTS OUT AT 5000 ROM Could u help (Stephdavis18)
Don't fix the problem...just bypass the sensor telling you there is on....real bright. Maybe you should figure out why you dont have oil pressure and/or wire up the oil pressure sensor to the ecu.
Old Jan 20, 2007 | 05:13 PM
vladd's Avatar
might seem obvious but have you checked your oil level? when's a buddy's car was low on oil vtec wouldn't kick in.
Old Jan 20, 2007 | 08:17 PM
JasonST's Avatar
Default Re: NO VTEC...MOTOR CUTS OUT AT 5000 ROM Could u help (civicdxtyper)
Obd2 vtec motors don't have Vtec oil pressure valve i'm told. What ecu u runnin? Is it obd1 ecu?
Old Jan 20, 2007 | 11:55 PM
95 integra's Avatar
Default Re: NO VTEC...MOTOR CUTS OUT AT 5000 ROM Could u help (JasonST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonST &raquo;</TD></TR><TR><TD CLASS="quote">Obd2 vtec motors don't have Vtec oil pressure valve i'm told. What ecu u runnin? Is it obd1 ecu?</TD></TR></TABLE>
Some JDM models dont have it.....all US (obd i and II) have it.
94wip
12
Jun 20, 2024 07:23 PM
crowder13
Mar 11, 2007 09:53 PM
robin_yanani
Jan 12, 2006 01:38 AM
red-eg6
14
Aug 17, 2005 01:11 PM
mugenracer
Oct 7, 2004 09:29 AM
