vtec help!
vtec help!
i have a jdm d15b in a 94 dx hatchback and i got a ex/si p28 skunk2 chiped ecu. i ran the vtec solenoid to A4 on the ecu and i ran the oil pressure to D6 on the ecu and i grounded the black wire. but when i use my volt meter i get a reading from the vtec solenoid but no reading from the oil pressure instead i get a negative signal in the oil pressure... do i need a reading from the oil pressure for the vtec to work?
Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">I thought the JDM D15B didn't have an oil pressure switch...</TD></TR></TABLE>
You'd think it had to have one to run vtec.
-Shane
-Shane
Re: (Luserkid)
yea the check engine light is on. and eather its for that or my broken vss sensor that i ghetto rigged to make it work on and off lol. im not sure how to get the engine codes out dont u have to jump fuses or sumthing? any give me a lil bit of help please?
Re: (silentblackhat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentblackhat »</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
LMFAO!!!! thats the best thing i have ever seen!!
Re: (nighttrain33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 »</TD></TR><TR><TD CLASS="quote">You'd think it had to have one to run vtec.
-Shane</TD></TR></TABLE>
I think the obd2 jdm engines dont have a vtec pressure switch...
Re: vtec help! (postman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by postman »</TD></TR><TR><TD CLASS="quote">vtec needs oil pressure switch</TD></TR></TABLE>
wrong, vtec needs a little TLC
Re: (red-eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red-eg6 »</TD></TR><TR><TD CLASS="quote">yea the check engine light is on. and eather its for that or my broken vss sensor that i ghetto rigged to make it work on and off lol. im not sure how to get the engine codes out dont u have to jump fuses or sumthing? any give me a lil bit of help please? </TD></TR></TABLE>
You also need VSS for VTEC.
https://honda-tech.com/zerothread?id=1171263
Go here to learn how to get your cel code.
94wip
11
03-24-2009 11:05 PM
vtecn8ive
22
08-03-2005 01:06 PM
