Question about starting up a sitting car
Old Jan 19, 2007 | 09:29 AM
Honda_Accord's Avatar
Default Question about starting up a sitting car
My car has been sitting in my drive way for about 6 months, and was wondering if theres any preps to starting it, if it sits that long? or can i just start it up and not worry
thanks in advanced
Old Jan 19, 2007 | 10:07 AM
walker111's Avatar
Default Re: Question about starting up a sitting car (Honda_Accord)
You could take some atf and dump it down the sparkplug tubes, first take the plugs out and only use about a cap full each cylinder. More than likely it will start right up though..
Old Jan 19, 2007 | 10:11 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Question about starting up a sitting car (walker111)
Whats does putting atf into the cylinders do exactly?
Old Jan 19, 2007 | 11:45 AM
Perfectionist's Avatar
Make sure the oil and other inportant fluids are OK. Turn the key to 'run' position and back to off a few times to presurize the fuel system and prime the injectors. Once the engine fires, let it idle a while and listen for any strange noises or behavior. Don't rev it. Once you're rolling, the brakes may feel crappy due to rust on the rotors. That should wear off after a while. You should probably change the oil as soon as you can.
Old Jan 19, 2007 | 12:05 PM
88LXi68's Avatar
Before you do anything check all fluid levels. Then I would remove the fuel pump fuse. Once the fuse is removed try starting the car. Obviously it wont start, but it will circulate the oil. Once you have done that put the fuel pump fuse back in and pressurize the fuel system.
Old Jan 19, 2007 | 12:57 PM
walker111's Avatar
Default Re: Question about starting up a sitting car (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">Whats does putting atf into the cylinders do exactly?</TD></TR></TABLE>
It will lube the rings if they have seized up at all and aid as a quick lubricant so they dont scratch the cylinder walls.
Old Jan 19, 2007 | 01:18 PM
philadd's Avatar
But, why ATF instead of, say, motor oil?
Old Jan 19, 2007 | 02:31 PM
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">It will lube the rings if they have seized up at all and aid as a quick lubricant so they dont scratch the cylinder walls.</TD></TR></TABLE>
ah, ok. But, like philadd said, why not just use oil?
Old Jan 19, 2007 | 03:06 PM
thanks for the answeres and quick replys
Old Jan 19, 2007 | 05:25 PM
sony224422's Avatar
ah, ok. But, like philadd said, why not just use oil?</TD></TR></TABLE>
i'd guess because its alot slicker and more of a lubricant than regular oil is, but im just guessing. Plus i'd change my oil after doing that, but you should anyways.
Old Jan 19, 2007 | 07:26 PM
Blamm!!'s Avatar
Default Re: (88LXi68)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88LXi68 &raquo;</TD></TR><TR><TD CLASS="quote">I would remove the fuel pump fuse. Once the fuse is removed try starting the car. Obviously it wont start, but it will circulate the oil. </TD></TR></TABLE>What? If just turning it over creates enough oil pressure to lube the bearings rings and cam then why not just start the ****** and get REAL oil pressure. Bad advice from 88lx
Old Jan 19, 2007 | 08:12 PM
Eddiebx's Avatar
Default Re: (Blamm!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blamm!! &raquo;</TD></TR><TR><TD CLASS="quote">What? If just turning it over creates enough oil pressure to lube the bearings rings and cam then why not just start the ****** and get REAL oil pressure. Bad advice from 88lx</TD></TR></TABLE>
yeah crank that bad boy right up and run it straight to redline, thats some real, oil pressure right there homo
Old Jan 20, 2007 | 01:59 PM
Blamm!!'s Avatar
Default Re: (Eddiebx)
cranking creates basically no oil pressure
Old Jan 20, 2007 | 06:10 PM
typhoon's Avatar
I hope 6 months ago you put some stabil in the gas tank, changed the oil and pulled the battery.(if it got below freezing where you are, that is)
Old Jan 21, 2007 | 12:29 AM
Blamm!!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">yeah crank that bad boy right up and run it straight to redline, thats some real, oil pressure right there homo </TD></TR></TABLE>cranking creates basically no oil pressure
Old Jan 21, 2007 | 05:24 AM
Ross 2.0's Avatar
In a Junkyard near you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blamm!! &raquo;</TD></TR><TR><TD CLASS="quote">cranking creates basically no oil pressure</TD></TR></TABLE>
Really now? you checked this?
When oil isn't at 160 degrees and cold (say ambient temperature) it's a lot thicker. Therefore the pump is able to pressurize it a lot easier even at very low rpm (about 500 with a normal car and good battery) After about 10 seconds of cranking it has good pressure.
Try hooking up an oil pressure gauge to the service port and you can see what i'm talking about.
But as far as starting this car that's been there for a few months. Just check the fluids and start it up, the instant that there isn't much oil isn't going to hurt it because there is no heat or friction yet. Before the heat even begins to show up the oil is already there.
What I would do though is disconnect the battery and touch the cables together, then start the car and let it run till the cooling fans cycle twice. (Idle learn has been done at that point)
good luck
Old Jan 21, 2007 | 11:57 AM
Blamm!!'s Avatar
Default Re: (Ross 4107)
not to argue but accoding to you, the motor will have about 10 seconds of dry cranking to possibly damage internals. that is why I suggest just starting it and getting the normal oil pressure. Maybe only 1 or 2 seconds to start up. I say add octane to compensate for the old gas and just start it and let er idle for while before driving.
Old Feb 8, 2007 | 05:43 PM
Default Re: (typhoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typhoon &raquo;</TD></TR><TR><TD CLASS="quote">I hope 6 months ago you put some stabil in the gas tank, changed the oil and pulled the battery.(if it got below freezing where you are, that is)</TD></TR></TABLE>
No unfortuantly i didnt put any stabilizer in the tank, i didnt think it would be sitting 6 months it wasnt planned and it didtn cross my mind. Oil was changed right when it sat (like i said the 6 month stand wasnt planned).
but its in the past now, obviously and its ran great sense i restarted it up, no problems yet.. if i didtn put any stabilizer in the gas tank.. is there anything i should be looking for , for future problems?
Old Feb 9, 2007 | 01:18 AM
philadd's Avatar
Default Re: (Honda_Accord)
No, you'll be fine. Many people believe thas gasoline degrades after sitting for only a few months, but it really takes much, much longer than that. At least with today's formulations it does...
Old Feb 9, 2007 | 02:07 AM
YeuEmMaiMai's Avatar
Default Re: Question about starting up a sitting car (philadd)
maybe due to amt of detergents in the oil...atf is great at cleaning carbon deposits........
Old Feb 9, 2007 | 04:06 AM
K24.20A's Avatar
Default Re: Question about starting up a sitting car (YeuEmMaiMai)
My brothers car has been sitting there for months now, and recently he started it without prepping it the way you guys said. It started to smog real bad. What should i do to fix this?
Thanks,
John
Old Feb 9, 2007 | 05:13 PM
Default Re: Question about starting up a sitting car (Made In Japan.)
Thought id just post in here instead of making a new topic.. is it possible for ur battery to just give out (it was 8 years old and was rated at only lasting 6 so i was impressed) and the battery light never come on and it just wouldn't start the car no more? because i mean car would start fine and drive fine, then one day i left it unhooked for a day or two, and it would never start again unless it was jumped and i finally had to replace the battery..
this has nothing to do with the sit, it just actually crossed my mind just now for some reason and thought id get yall to educate me a little further
so again question is, is it possible for the battery light to never come on and the battery just die (sense im dumb and forgot to hook it back up one day) and never start the car again? just crossing my fingers that it was nothing except just the battery.
Old Feb 11, 2007 | 01:38 PM
sony224422's Avatar
yeah, if the battery is that old i wouldn't worry about it. And the light wouldn't come on unless it detected a low voltage, IE, your alternator wasn't charging the battery or charging at all. but since the alt. was working and doing its job, the light wouldn't come on for a dead battery.
Old Feb 11, 2007 | 04:37 PM
Blamm!!'s Avatar
Default Re: Question about starting up a sitting car (sony224422)
BTW new gas turns bad much sooner than older formulations. !! ethanol anyone?
Old Feb 11, 2007 | 07:02 PM
philadd's Avatar
Default Re: Question about starting up a sitting car (Blamm!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blamm!! &raquo;</TD></TR><TR><TD CLASS="quote">ethanol anyone?</TD></TR></TABLE>
Didn't think about that...
Kyrus
17
Sep 2, 2016 08:19 PM
RDAYA0
14
Apr 17, 2008 03:42 PM
labtec2
Sep 4, 2007 11:09 AM
EKris
Mar 4, 2007 08:37 AM
2DXtreme
10
Mar 11, 2005 06:48 AM
