04 ep5 short shifter
Old Jan 18, 2007 | 09:33 PM
shllipperybert's Avatar
Default 04 ep3 short shifter
does any one have it in there ep3 if so do u like it and how much was it total part+install i was wouldering if its worth it
Modified by shllipperybert at 10:45 PM 1/18/2007
Old Jan 19, 2007 | 01:24 AM
JCL's Avatar
JCL
avg short shifter eg. bc is about 160 ish and installation is pretty much DIY 1 outa 10..
Old Jan 19, 2007 | 02:53 PM
C4st0r_Tr0y's Avatar
Official H-T Cake Maker
Default Re: (JCL)
buddy club is the best out there.
ive seen it for $130 someplaces
Old Jan 19, 2007 | 03:19 PM
...me0w's Avatar
do you really need one in the ep i find it short enough stock but thats just me.............
Old Jan 19, 2007 | 05:48 PM
Default Re: (...me0w)
i was j/w if it is worth it i like it just fine the way it is but if not a lot of ep owners have it then mine would stand out just a lil
Old Jan 20, 2007 | 01:34 AM
JCL's Avatar
JCL
well. you could get shifter bushings and the cables and call it a day.
Old Jan 20, 2007 | 09:30 AM
BarracksSi's Avatar
I had a Neuspeed short shifter (not as nice as the BC assembly, but still shorter front-back throws than stock), then eventually took it back off. I agree, it's still pretty short stock, and I think I like it better this way.
I've also got an aluminum Honda **** on it (optional base RSX 5-spd, just like the CTR **** except for the pattern and letter color), and it feels pretty darned good overall. I've thought about an FG2 or S2K leather-aluminum **** for better hot & cold weather feel, though.
Old Jan 20, 2007 | 08:15 PM
Default Re: (BarracksSi)
i tried to change the **** b ut that silver thing on the shift rubber that attaches to the stock shifter looked weird cuz it was just there so what after market **** do u recomend
Old Jan 21, 2007 | 11:07 AM
jdmrazing's Avatar
short shifters are pretty much just another modification to make you feel like a good driver. you could save that 150 to get some power to the ground or many other parts that would help you. All you need is to shift your arm faster, pros still use stock shift levers, so why cant you?
Old Jan 21, 2007 | 12:05 PM
talonxracer's Avatar
The BC ss absolutely rocks! It blows away the Neuspeed POS.
Old Jan 21, 2007 | 04:29 PM
BarracksSi's Avatar
Default Re: (shllipperybert)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shllipperybert &raquo;</TD></TR><TR><TD CLASS="quote">i tried to change the **** b ut that silver thing on the shift rubber that attaches to the stock shifter looked weird cuz it was just there so what after market **** do u recomend</TD></TR></TABLE>
There's a few things you can do with the shift boot & chromed plastic clip...
You could buy an OEM Type-R shift boot. It has a small chromed ring on top that goes well with any aftermarket ****, and a larger rubber boot to keep it from sagging. ICB Motorsport has them at a good price:
http://yhst-1408381693991.stor....html
You could buy or fabricate another shift boot to replace the stock one. I've seen some in red-stitched suede that match the seats.
Also, the aluminum base RSX **** I mentioned came with an alternate black plastic ring that would replace the chrome clip. Supposedly, it's been available separately from Acura dealers, but you may have to do some digging to find it these days.
Lastly, and for free, you could somehow invert the stock clip & ring to clean up the top of the boot. I didn't quite figure it out myself and ended up snapping the clip tabs and supergluing everything together.
IMO, the best option is the CTR shift boot. Looks clean, factory fit, and really isn't any more expensive than the USDM boot.
Old Jan 21, 2007 | 09:07 PM
20CiviC02Si's Avatar
Default Re: 04 ep3 short shifter (shllipperybert)
Depends on what you're looking for! The Buddy Club S/S is about 150 and is a direct replacement assembly where as the Neuspeed is about 100 and is an adapter that is installed on the shifter!
Old Jan 23, 2007 | 05:30 PM
how hard is it too install the not shifter cover ur self it looks like 3 bolts does any body know ???
Old Jan 24, 2007 | 04:02 PM
BarracksSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shllipperybert &raquo;</TD></TR><TR><TD CLASS="quote">how hard is it too install the not shifter cover ur self it looks like 3 bolts does any body know ???</TD></TR></TABLE>
It's cake; I can probably swap one for the other in fifteen minutes. The difficult part is pulling the fascia from the dash. Let's see how concise I can be...
- Pull the chrome ring down and unsnap it from the shift ****, then unscrew the ****.
- Poke your thumbs into the top of the shift boot and begin tugging -- gently -- at the silver part of the lower dash. There are three clips to unsnap; the difficult one for me is in the upper right.
- Disconnect the plug for the hazards button.
From here, it's easy -- you'll see three screws holding the shift boot to the dash piece. I think you'll be able to figure it out after that.
Old Jan 24, 2007 | 06:47 PM
oh ok kool souds easy my dad said he would order it for me for a little b-day gift so i cannot wate till it gets in
Old Apr 4, 2007 | 09:07 AM
well yea i got it on it was like a 5 min job i also put on the spon **** silver looks way better with the type r boot and not the stock one hanx for all the help
Old Apr 4, 2007 | 09:45 AM
j-bird's Avatar
I am holding off getting the BC short shifter until i swap to a 6 spd tranny so i don't have to modify the stock shifter.
SoyMilk
55
Mar 27, 2010 10:11 AM
Tiger_Si
Aug 15, 2008 12:47 PM
Juanda_084
Feb 27, 2007 06:46 PM
JDean6pac
Feb 21, 2006 10:38 AM
tdog
Feb 11, 2002 06:35 PM
