cant drive at night plz help
Old Jan 18, 2007 | 08:20 PM
krazyhmongboi's Avatar
Default cant drive at night plz help
wiring up my city lights i messed something up and had to wire my corners/taillights to my DEPO foglight switch..i had the foglights on before and took them off cause i switched bumpers..but aniwaise..my switch burnt on me and now my corners or tails dont work..the front corners still work with turn signals..but what im asking is if there is anything that i can wire up so i can drive at night?..like use power from the battery? i tried it but the wire was getting warm..what i did was used some wire to connect a switch from the battery and cut the power wire from the switch, it was working but the battery wire was just getting hot..anyone have any ideas?..im going to order a new foglight kit tomarrow and throwing my other bumper back on so hopefully then it'll work but need to find another way around it until then..hope you understand what i mean thanks in advance
Old Jan 18, 2007 | 08:31 PM
bpr0422's Avatar
Default Re: cant drive at night plz help (krazyhmongboi)
huh??? what exactly did you do??
First put it all back to stock wiring...
Then check your fuses...
The switch burnt cause it shouldn't be controlling the actual lights, it should only be controlling a relay...
Whenever you hook something up directly to the battery, it should have a fuse that is rated for the circuit/wiring... no more than 12" away from the battery...
BAT ---(12" Wire)--- Fuse --- (Wire) --- etc..
Read this:
http://www.danielsternlighting....html
I dunno how you screwed up wiring your city lights.....
maybe you should ask a professional shop to redo the wiring for you...
you could also go to the junk yard, and buy new harnesses...
Old Jan 18, 2007 | 08:36 PM
would it work if i hooked it up temporarily to the battery with an inline fuse? but im about to take my city lights off and tap the corners to the headlight..sigh..i have a headache
what i did was when i tried tapping the city lights to the power of the corners and the power(red/yellow i think) of the headlight (so it turns off) fuses blew and from there i just had to do something for them to work.. so i had foglights switch that i wasnt using because i changed from a bumper with foglights to one w/o..but i just drew power from the power of the foglight, which went to the battery through a 20amp fuse
Old Jan 18, 2007 | 11:12 PM
ridin98civic's Avatar
Default Re: (krazyhmongboi)
so when you blew the fuses why didnt you just replace the fuses? before hacking your factory harness and attempting the depo switch fix
Old Jan 18, 2007 | 11:18 PM
Eran's Avatar
HT White Ops
No offense, but you really need to never touch the wiring on your car again. It's obvious you have zero clue what you're doing. For you to screw something up so badly when splicing a grand total of 4 wires is mind-boggling. Then to hack up the rest of your wiring because of a couple blown fuses?
What you need to do is undo what you have done. Take out your city lights, resplice your original wires back together, put everything back to stock as best you can.
Old Jan 18, 2007 | 11:35 PM
nello a.'s Avatar
Default Re: (Eran)
^what he needs to do is leave it alone. nothing personal to op but, take it to someone who knows how to wire something safely and properly.
67mmlsv
Nov 6, 2013 08:53 PM
Evan125
Dec 3, 2009 10:41 AM
fryman
Aug 30, 2009 07:48 PM
integraXTC
Aug 4, 2005 08:27 AM
Driven
13
Jan 26, 2003 11:45 AM
