00 Si running like shit after snow storm (2 weeks)
i had my car inside my garage for about 2 week.
car runs normal until i hit 4k and on.
im thinking there could be water in my gas tank. i bought some gas water remover product and hopefully this is the problem.
anyone had this problem before.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruben19 »</TD></TR><TR><TD CLASS="quote">bogging but not all the time</TD></TR></TABLE>
I'd start by running a bottle of HEET through the gas tank, and changing your oil. Some basic maintenance can't hurt.
i used Heet yesterday.
i ran the car for about 20miles already.
i think it take a while to work but im trying to burn this gas ASAP.
Im going to check my spark plug to see how they are burning.
Gas is way down now (yay!)...you could always just drain the tank and refill it. Thats if you really think bad gas is the issue.
Just undo the plastic tank cover and remove the drain plug.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">Gas is way down now (yay!)...you could always just drain the tank and refill it. Thats if you really think bad gas is the issue.
Just undo the plastic tank cover and remove the drain plug.</TD></TR></TABLE>
Hell, you could just save your drained gas, add some two-stroke additive, and mow lawns for a year
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruben19 »</TD></TR><TR><TD CLASS="quote">i pulled the spark plugs and they are all brown.
Oil on your spark plugs. Boo. Change them, run them for a tank, and check them again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruben19 »</TD></TR><TR><TD CLASS="quote">is not oil.
The entire plug is brown, or just the contacts?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruben19 »</TD></TR><TR><TD CLASS="quote">just the conacts.
Ah, I took "all brown" to mean the whole thing
Just go buy some new plugs. If you had water in your gas, it probably fouled the crap out of them when you started up.
Layziebtnh055
Oct 20, 2004 08:37 PM
