Hatch wont and will start
Old Jan 18, 2007 | 06:50 PM
BluRgio's Avatar
Default Hatch wont and will start
ok heres the deal i own a 93 hatch and about a month ago it would take more than 15-20 seconds for the fuelpump to kick in so i thought it was the main relay so i waited the whole month to buy it so when i changed it kept do that but even worse so while i was at the store it doesnt start for like a whole hour There was no spark and the fuel pump wasent working so i towed it to the shop and left it over night and by the morning it turn on and work fine for like 5-10 minutes and it shut off and did the same thing
Cliff Notes:
Brand new main relay from Honda
Car has no spark and fuel pump kicks in when it wants
But after a while it turns on fine but only lasts a good 5-10 minutes
Old Jan 18, 2007 | 06:52 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: Hatch wont and will start (BluRgio)
no cels? this could be many things
Old Jan 19, 2007 | 05:50 PM
BluRgio's Avatar
no check engine lights it just stays on when key is forward then when it turns off the pump kicks in and it starts right up
Old Jan 20, 2007 | 04:52 PM
BluRgio's Avatar
i was told it was the fuse box under the dash could it be this
Old Jan 20, 2007 | 04:55 PM
Otherguy's Avatar
NASIOC.com
Default Re: (BluRgio)
I would do this...
Replace your cap and rotor, spark plugs, spark plug wires. Btw... hows your battery?
Old Jan 20, 2007 | 06:09 PM
BluRgio's Avatar
everything above is new except for batttery but it holds up charge
Old Jan 20, 2007 | 10:19 PM
Targa250R's Avatar
be professional
Sounds like a possible problem with the ignition switch.
Old Jan 20, 2007 | 11:55 PM
fmrprojects's Avatar
Default Re: Hatch wont and will start (Targa250R)
dude i had the same problem, its the ignition switch, the contacts are not touching.
Old Jan 28, 2007 | 10:06 AM
BluRgio's Avatar
^^^ would your car still turn over
Old Jan 28, 2007 | 04:52 PM
assa9eg's Avatar
have you changed you fuel filter lately I have had a few cars that the filter was so clogged that the car would run on fuel left in the line and shut off due to poor fuel flow.
Old Jan 28, 2007 | 05:06 PM
cherryhatch00's Avatar
Check fuel filter. If that isn't the case..
Do like everyone else says. Ignition switch.
hamburgler
Aug 21, 2011 10:23 AM
olschool92
Jul 25, 2011 02:38 PM
pmey
May 26, 2009 01:11 PM
slavagc8
15
May 26, 2009 06:17 AM
Red1ine
Apr 2, 2008 10:09 AM
