Somebody Please Help
Old Jan 18, 2007 | 04:06 PM
93 EG's Avatar
Default Somebody Please Help
I know this is probably an easy answer for you guys but I have searched all over
and cannot find out how to fix my idle. One of my friends just chipped my ECU with
a skunk2 program. I thought it was my MAP sensor, so I replaced it, but still the same. My idle jumps from 700-1200 RPMs. Any help would be greatly appreciated, Thanks.
Old Jan 18, 2007 | 04:09 PM
VRD^sam's Avatar
Default Re: Somebody Please Help (93 EG)
recheck your ECU if it isn't that then replace your TPS
Old Jan 18, 2007 | 04:15 PM
93 EG's Avatar
will do, thanks.
Old Jan 18, 2007 | 07:15 PM
slayerfromhell212's Avatar
go here bro
https://honda-tech.com/zerothread?id=699787
Old Jan 31, 2007 | 11:42 AM
93 EG's Avatar
hey I replaced my IACV and my MAP sensor and I still have my Idle problem. So I replaced my chipped ecu with a stock p28 ecu and still have the problem. What would you guys recommend me doing next?
Old Jan 31, 2007 | 11:44 AM
turbociviccoupe's Avatar
Default Re: (93 EG)
it sounds like you might have a vacuum leak. did you check all your vacuum lines?
Old Jan 31, 2007 | 12:28 PM
93 EG's Avatar
Default Re: (turbociviccoupe)
No, I am doing that next, but if that werent the case is there anything else you could think of?
Modified by 93 EG at 2:41 PM 1/31/2007
Old Feb 10, 2007 | 12:39 PM
93 EG's Avatar
I dont have a FITV underneath my Throttle Body. My check engine light is not lit and I am not throwing any codes, so I dont think it could be my TPS. What would you guys suggest?
Old Feb 10, 2007 | 01:30 PM
93 EG's Avatar
bump
Old Feb 10, 2007 | 01:37 PM
IheartFLATblack's Avatar
there is a great write up on this in the archives.
b_serious
Dec 1, 2005 08:21 PM
LS_VTEC_Hybrid
Oct 14, 2005 09:52 PM
hatchlessrex
May 12, 2005 06:13 PM
F120man
Dec 18, 2003 06:32 PM
Hnda_Crx_Man
Feb 9, 2002 12:58 AM
