WHen to bore and when to hone
Old May 15, 2002 | 05:38 PM
1.8EG-T's Avatar
Default WHen to bore and when to hone
I am currently buying parts for my build this summer, but I am unsure of when to bore and when to hone. WHat do I look for on the cylinders and so forth.
Old May 15, 2002 | 06:31 PM
fastestdriver's Avatar
Default Bore/hone
You want to look for scoring, and measure for excesive cylider wall taper/out of round. If you are building a new motor it's always a safe be to go up to the next size of piston (usually 0.010") and know that the cylider walls are good and true.
Old May 15, 2002 | 06:40 PM
Quetzolcotl's Avatar
Default Re: WHen to bore and when to hone (hybridrex)
honing is to recondition the cylinders from scratches made by the pistons & rings, you clean it up like new again. it keeps bore close to stock. boring is if you want more displacement by enlarging the bore. you can bore out with a hone but it takes a while. if you want an increase of 1/2 mm then hone, more than that bore.
Old May 15, 2002 | 07:56 PM
Halo's Avatar
Default Re: WHen to bore and when to hone (Quetzolcotl)
But remember you can only bore so many times before you need sleeves
Old May 16, 2002 | 12:42 AM
Rocket's Avatar
Default Re: WHen to bore and when to hone (Halo)
Just pick a good machinist. It's the machinist call as to how he'll do the cylinder resizing. Just ask him to follow Honda's recommend finish honing specs.
xander1100
Apr 13, 2009 03:17 PM
Yambor
Apr 29, 2005 10:55 PM
94tegdude
Feb 15, 2005 10:33 PM
Chuji
Sep 11, 2003 09:00 PM
