Need new CV axle
Old Jan 18, 2007 | 05:36 AM
dan_g's Avatar
Default Need new CV axle
1993 Honda Civic LX, 187k miles
Just found out that the passenger side CV axle boot is cracked.
Both front axles were changed at 114k miles six years back, Is this a normal lifespan?
I am planning to do this myself, wanted to know what axles are good or any recommended.
Thanks
Dan
Old Jan 18, 2007 | 05:53 AM
JShull's Avatar
Your local parts store should be able to hook you up with axels for like $60 (after core is exchanged). The boot cracking is normal. I've had them crack in less and had to replace the boots.
It's super easy. It should only take around an hour to change it out.
Old Jan 18, 2007 | 06:16 AM
dan_g's Avatar
Default Re: (JShull)
Should I just change the axle or try replacing the boots?
Old Jan 18, 2007 | 06:53 AM
Jakester9500's Avatar
Default Re: (dan_g)
the axle, or at least that's how i did it
Old Jan 18, 2007 | 06:57 AM
oc_civic's Avatar
Default Re: (Jakester9500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jakester9500 &raquo;</TD></TR><TR><TD CLASS="quote">the axle, or at least that's how i did it</TD></TR></TABLE>
X2 i just did mine.. the work can be a SLIGHT pain in the ***.. so imo its better just to do a brand new axel and get it done..
Old Jan 18, 2007 | 08:13 AM
hondaman86's Avatar
Default Re: (dan_g)
just replace the whole axle
Kaliona
Jul 6, 2009 08:21 PM
Tad
15
Mar 12, 2007 12:04 PM
NstyGrnHatch
10
Feb 15, 2005 11:35 AM
sinfulDB1
Dec 2, 2003 10:53 AM
gooberwolf
Sep 6, 2003 12:05 PM
