Itg Filters
Old Jan 17, 2007 | 09:23 PM
87mugenprocr-x's Avatar
Default Itg Filters
For those running ITG filters on your ITB's or specifically on Sidedrafts what part # have you ordered and from where? Input is appreciated.
Julian
Old Jan 17, 2007 | 09:34 PM
d16dcoe45's Avatar
Default Re: Itg Filters (87mugenprocr-x)
I can look up the Pipercross part number for the one piece foam with one piece backing plate--that is what I run on my carbs--identical to ITG--although some people say the ITGs are a little better quality. there is a pic in the carburetor post..
Old Jan 17, 2007 | 09:36 PM
d16dcoe45's Avatar
Default Re: Itg Filters (d16dcoe45)
go to http://www.truechoice.com you order the backing plate seperate (or you can make one, its just a simple aluminum sheet which you will have to drill yourself anyway for the carb runners) and you can get the foam filter from 2" all the way to 6" deep if you can fit it.
Old Jan 17, 2007 | 09:40 PM
jdmintegraxsi's Avatar
I run the pipercross filters, and from what I have been told are very similar to the ITG. Only lost about 2-3whp on the dyno.
I used this base plate http://truechoice.com/prodinfo...C6006 with this filter http://truechoice.com/prodinfo...C604D
They work great on my TWM ITB's.
Old Jan 17, 2007 | 11:33 PM
Default Re: Itg Filters (jdmintegraxsi)
Awesome thanks for the info guys.
Julian
Old Jan 18, 2007 | 05:01 AM
d16dcoe45's Avatar
right, exactly what I use. There are the same style, but I hear ITG has beefier base plates.
Old Jan 18, 2007 | 06:04 AM
Importracer_001's Avatar
I had a ITG filter on my turbo and it almost ruined it.
There is a kind of screen inside the filter which came almost completely loose and was being sucked in by the turbo.
Thank god I saw it before it got completely sucked in.
Old Jan 18, 2007 | 08:14 AM
d16dcoe45's Avatar
Default Re: (Importracer_001)
That was a cone filter though, right? These ITB/Carb filters are one-piece about 13-17" wide--they do have the metal screen inside to give support but its pretty beefy.
Old Jan 18, 2007 | 10:44 AM
Default Re: (d16dcoe45)
No one else running the ITG's? I'm worried about the dimensions of the filter and teh clearance that i have with my MC does any one have a pic with these filters installed?
Julian
Old Jan 18, 2007 | 01:57 PM
SuperTwinz's Avatar
Default Re: (87mugenprocr-x)
Jenvey makes a few sizes too.
Old Jan 18, 2007 | 06:04 PM
d16dcoe45's Avatar
Default Re: (SuperTwinz)
those are nice--they look like they are made by Pipercross or ITG for Jenvey. One thing with the foam, you really have to use the sticky, sticky oil they provide or else the filtering (as far as trapping debris) isn't very good.
Old Jan 19, 2007 | 05:57 AM
yeah the one I was using was a cone filter
hondacrx2
35
Oct 17, 2011 08:26 AM
hondamn1320
Feb 28, 2008 05:10 AM
BlueJdm
May 12, 2007 03:18 PM
