Oil filter vote
Technical Hero
Re: Oil filter vote
http://minimopar.knizefamily.net/oilfilters/index.html
http://www.300cforums.com/forums/gen...dissected.html
AO2 VS Old PT7-006 Filters
http://www.tegger.com/hondafaq/oilfi...r_comparo.html
A01/A02 Cut Away
https://honda-tech.com/forums/honda-civic-2001-2005-78/whats-honeywell-2331329/
http://www.d-series.org/forums/gener...il-filter.html
FRAM/FRAM Extended Guard/FRAM Toughguard/Purolator PureOne/SuperTech(Walmart)/A01/AO2 Cut Away
http://www.ridgelineownersclub.com/f...ead.php?t=7544
PCX (Toyo Roki & Filtech) Cut Away pg2
http://www.s2ki.com/forums/index.php...c=473347&st=25
A01/A02 Cut Away
Re: Oil filter vote
Re: Oil filter vote
Years ago, when I first started driving and doing my own maintenance I used Fram. It was cheap and easy to get at most places. About 15 years ago I read some of the reviews similar to the one quoted by Ron, and that did it for me. I have never used anything made by Fram again nor will I. I currently use Wix on all of the vehicles I have at my house and have been using them for 10 years or so. Occasionally there will be a Mobil or Purolater Gold filter thrown in there if I catch them on sale with oil at Autozone or Advance.
Re: Oil filter vote
If you read all these they contradict each other. What is the best filter with out spending 20$? What gives best starts and filtration ect. I do oil changes every 3k religiously so it won't be over 3k.
Ek Forever y0!
Re: Oil filter vote
The A02 filter is a bit different than the A01. The A02 being much more similar to the Fram, the A02 tested much better.
But it seems to me Wix and Supertech from walmart are good cheap brang for the buck options.
Re: Oil filter vote
oem honda filter, imo. The seal is a P ring instead of an O ring, so it won't stick on when you take the filter off. They also have a anti drain back system to keep the **** they filtered from getting out.
Re: Oil filter vote
Funny, I literally just got back from the dealer and grabbed a honda filter for $7. I glanced at a sign they had that said "Why use a Honda oil filter." Unfortunately, I did not read further lol.
Re: Oil filter vote
I use Mobil1 filters in the d15b7 and Mann brand filters in my Volswagen TDI engine.
[The Mann filters are sick. The engine has the filter housing built in on the top side so just the element is changed. The element alone is about twice as big as the entire filter for the Honda.]
I've only ever heard good things about WIX and Mobil1 filters.
