H22a hatch idles
my lil bro's h22a hatch idles roughly...i dont think its a vacuum leak however...cause i checked them all for him....got new spark plugs....compression test shows that its good...can it be ignition coil..or somethin else maybe?
Is this rough idle like a high idle??? Have you adjusted the fast idle valve under the throttle body??? my H22 sounded like crap in the mornings when I would turn it on, I adjusted it and it's normal now.
ill check it out thanks...the car is running on a GSR ECU right now with no check engine light and no idling...if the P13 is put back on it idles plus the check engine light is on it idles real bad from 500rpms to 1500rpms...it seems like a valve or head gasket but if so then the car would also die which i have had two bent valves on my car before....so im really not sure wat it is..thats why i ask
alrite the car idles not from the start but after the car is driven for maybe a quater of a mile and the car is at a dead stop..then it just keeps idling...
why dont you understand, u CAN NOT run a STOCK h22 on a GSR ECU, IT WASNT MADE FOR THAT ENGINE, THERE IS A DIFFERENCE- ITS A DIFFERENT ENGINE WITH DIFFERENT FUEL AND TIMING MAPS TO MENTION A FEW OMG!
Its like reading this (examp)
"hey guys my car runs like a complete piece of crap, its an H22, but i have a GSR p72 running it, now i cant figure out why it doesnt run right"
Well duh get the right ecu, how hard is that, get the right ecu check and fix all the codes, and guess what, it will probably idle fine!!
man somebody really needs to read the FAQ's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by l2yanE »</TD></TR><TR><TD CLASS="quote">why dont you understand, u CAN NOT run a STOCK h22 on a GSR ECU, IT WASNT MADE FOR THAT ENGINE, THERE IS A DIFFERENCE- ITS A DIFFERENT ENGINE WITH DIFFERENT FUEL AND TIMING MAPS TO MENTION A FEW OMG!
Try a p13 then let us know what the CEL code is.
