Is 13.5.1 to much compression for daily use?
Old Jan 17, 2007 | 04:42 PM
Red_ED8's Avatar
Default Is 13.5.1 to much compression for daily use?
On a mild K20a with K-Pro, headers, CAI, valve springs, cams, and cam gears, is 13.5.1 pistons to much to be used as a daily driver? Or better, is this to much compression for a 90% stock block and head?
Old Jan 17, 2007 | 08:18 PM
eMpAtHy's Avatar
Default Re: Is 13.5.1 to much compression for daily use? (Blue_DX)
are you going to retard the timings like crazy? if you are, then i dont even think its worth going that high. if you're not, make sure u can get high octane gas.
on the topic of it being a daily driver, i would have to say no. can you honestly afford octanes higher than 91? 91 octane is almost 3 dollars a gallon down here in so cal. its hanging around this price and i dont see prices dropping drastically anytime soon. so, if you're going to do some sort of 50% 100 octane and 50% of 91, it might cost u around 4 dollars a gallon. if cost goes up, so does your gas, so you might want to think twice about going so high. also, you have to hope you never ever get bad gas
Old Jan 18, 2007 | 05:14 AM
Red_ED8's Avatar
Default Re: Is 13.5.1 to much compression for daily use? (eMpAtHy)
Thanks, that is exactly what I was looking for.
Old Jan 20, 2007 | 12:14 PM
archull's Avatar
I wouldn't go over 12.0
Stock compression is fine, its already 11.5
Old Jan 21, 2007 | 09:21 PM
20CiviC02Si's Avatar
Default Re: Is 13.5.1 to much compression for daily use? (archull)
I think that 12.5:1 would be max comp ratio for a daily driver!
Old Jan 22, 2007 | 09:50 PM
eMpAtHy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by archull &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't go over 12.0
Stock compression is fine, its already 11.5</TD></TR></TABLE>
stock is 11:1. the highest honda/acura has for their production cars in the US is 11:1. they had this on their k series and the f20/22. i think the TL also has 11:1. not sure about other honda/acura cars.
Old Jan 22, 2007 | 09:52 PM
inkong's Avatar
can you keep up with the gas prices is more the question in my opinion
Old Jan 23, 2007 | 05:48 PM
01-0720's Avatar
Default Re: Is 13.5.1 to much compression for daily use? (inkong)
if you run 93 octane, and have k pro you whould be fine with that comp ratio, if you have a good tuner
but it whouldnt do you any good, you whouldnt make any more power with that comp ratio, over say 12.5:1, theres no reason to go that high with stock head, stock cams, stock im, and stock block, there whould be no real gains from it
meanshyguy
Apr 1, 2007 10:23 AM
norcalbayboy
29
Aug 7, 2006 10:08 PM
AllmotorJunkie
Jul 14, 2003 02:15 PM
AllMotorITR
Sep 30, 2002 09:33 PM
Rocket
May 5, 2002 12:32 PM
