Successful AVIC-Z1 Install
500 for the install of ur system? what did that include? hope not just an ampsub install. ur ampsub installs ok.. good have looked better. was the vss wire easy for u to hookup? that wire is usually the pita. good work
Sushi Buffet Champion
Still kinda messy since I just finished yesterday.
$500 installation included:
-Front & Rear Components
-Power/RCA runs
-2 ch. & 4 Ch. amp
Instead, I built my own box, ran the cables (4 gauge & quality RCA's), xover, added power cap, retrofited 6.5" components into 4" stock panels, bypass factory system, etc.
$350 installation for navigation - I completed it myself in 1.5 hours. I hooked up the unit without the VSS and everything worked perfectly, in 3D model and all. It detected my speed, direction, etc. before I even hooked up the VSS. VSS is just behind the cluster, so that was easy.
-Power/RCA runs
-2 ch. & 4 Ch. amp
oh i can see why they wanted so much. 2ch,4ch, ampsub, front and rear components. what type of vehicle and how did u bypass the factory amp? did u run your own lines thru the doorjams and what not or did u tap the lines to the output of the factory amp? i wanna see some pics of ur retrofit as well. might give me some ideas.
Car is a Lexus GS. I tapped into the factory wires. The factory system no longer have anything to do with this one, I completely unplugged everything. No pics of the retrofit, but I used speaker ring adapters and insulated the back.
There are several ways to bypass a factory amp.
Replace all wiring (no shops do this)
Loop OEM amps inputs to the outputs (shops prefer this)
Run speaker wires from behind deck to OEM amp outputs (shops are often forced to do this)
Find speaker connections in the individual B pillars and front kicks (last resort)
Which method is chosen is based on how the OEM amp is wired. If it's individual speaker wires from the deck to the amp, you can just loop it at the amp. But a lot of shitty companies have line level outputs mimicking RCAs, or common ground, or something else stupid.
Going rate in so cal for an in-dash navigation assuming no serious custom work is required is $180.
onemanlan
Audio / Security / Video
May 16, 2004 11:51 PM
Calavera
18
Aug 13, 2003 10:32 AM
