capacitor install help!
Old Jun 12, 2007 | 02:01 PM
turboteg86's Avatar
Default capacitor install help!
I bought a 1.0 farad cap for my eclipse sound system and need to install it but never have. I read some installation instructions on how to install but never really understood, so if anyone can give me detailed instructions on how to install it I would appreciate it. P.S. Have a red optima red top relocated in the trunk so everything is back there.
Old Jun 12, 2007 | 02:03 PM
turboteg86's Avatar
Default Re: capacitor install help! (turboteg86)
And do you have to charge the cap before you install it like some people say or just install it and turn on the car and you're done.
Old Jun 12, 2007 | 02:20 PM
nsxxtreme's Avatar
Charging prevents arcing which could damage the bling factor. If you dont care just hook it up.
The intent is to install a cap as close to the subwoofer amplifier as possible.
You connect it in parallel with the amp.
Old Jun 12, 2007 | 10:18 PM
turboteg86's Avatar
Default Re: capacitor install help! (nsxxtreme)
how do you charge it though??
Old Jun 13, 2007 | 01:26 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Thru a light bulb or resistor that came with the unit.
Old Jun 13, 2007 | 06:14 AM
02 accord's Avatar
Pull out the fuse from the wire that feeds the system, hook everything up, and then install the light bulb in place of the fuse. At first, it will glow, and then slowly it will go out. When it goes out, reinstall the fuse.
Old Jun 13, 2007 | 06:48 AM
StreetRacin101's Avatar
If its missing the light bulb/resistor... what can you use?
Old Jun 13, 2007 | 07:16 AM
02 accord's Avatar
Default Re: (StreetRacin101)
Any 20 watt bulb would do.
turboteg86
Audio / Security / Video
Jun 11, 2007 10:16 AM
CzanSOHC
Sep 6, 2002 07:46 PM
