Symptoms of a defective ECU?
Old Jan 16, 2007 | 07:17 PM
erikiksaz1's Avatar
Default Symptoms of a defective ECU?
If you have a defective/fubared/defunct/broken ECU:
Will the car idle at all? Or hell, will the car even turn on? What are some telltale symptoms?
OKAY, we figured it out, it was his car. The ecu was reading just fine. We tested his car with another fresh p28 and it gave off the same code.
Modified by erikiksaz1 at 10:52 PM 1/22/2007
Old Jan 16, 2007 | 09:58 PM
Private-Tune's Avatar
Default Re: Symptoms of a defective ECU? (erikiksaz1)
I've had a few that just wouldnt rev out past like 3500 rpm and another one that caused a misfire because it shorted the signal to the injector
Old Jan 17, 2007 | 05:06 AM
Furyof4's Avatar
Default Re: Symptoms of a defective ECU? (Private-Tune)
I think usually if an ecu is bad/defective it will run in limp mode with a solid cel.
A little info on trouble shooting:
http://www.pgmfi.org/twiki/bin...oting
Old Jan 17, 2007 | 10:39 AM
Relic1's Avatar
putting one symptom on a defective ECU is like placing one symptom on a defective car. There are too many little things that can be wrong to put one result to it.
Commonly if the ECU has a bad chip job it will have a solid CEL and a revlimiter of 3500 but idle will be ok.
If you suspect the ECU try a different one.
If you can't do that simply pull off the cover and take a smell, it will smell really foul if something is blown.
But even if it doesn't smell that's doesn't mean that it's good.
What are the symptoms and troubles that you are having?
skyliner34life
Engine Management and Tuning
Jul 5, 2016 06:05 AM
TurboBA8
Feb 20, 2007 07:25 AM
cheehee
Sep 6, 2006 05:02 PM
b16ahybrid
Feb 13, 2006 02:44 PM
impact_blu
Aug 18, 2005 01:36 PM
