Filling tranny fluid?
Old Jan 16, 2007 | 11:37 AM
invisible's Avatar
Default Filling tranny fluid?
is this right. red is the drain plug, green the fill plug? also read you have to disconnect the VSS, where is that at?
is this the VSS?
Modified by .Huey at 5:24 PM 1/16/2007
Old Jan 16, 2007 | 11:43 AM
my_slow_civic's Avatar
Default Re: Filling tranny fluid? (.Huey)
Green plug. You do not need to disconnect the VSS to fill the fluid. Some people prefer to fill in through the VSS hole though.
Old Jan 16, 2007 | 11:44 AM
invisible's Avatar
Default Re: Filling tranny fluid? (my_slow_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my_slow_civic &raquo;</TD></TR><TR><TD CLASS="quote">Green plug. You do not need to disconnect the VSS to fill the fluid. Some people prefer to fill in through the VSS hole though.</TD></TR></TABLE>
so the green is the fill hole? do i just get a funnel and hose to pour it in?
Old Jan 16, 2007 | 11:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Huey &raquo;</TD></TR><TR><TD CLASS="quote">
so the green is the fill hole? do i just get a funnel and hose to pour it in?</TD></TR></TABLE>
Yep. Or a pump that attaches to the fluid bottle.
Old Jan 16, 2007 | 11:53 AM
pdiggitydogg's Avatar
filling via the vss hole is 100x easier
Its on top of the tranny, near the back.
Sticks straight up, about 3" tall with an electrical connector.
Remove one 10mm bolt, pull it straight up.
Pour in fluid
Old Jan 16, 2007 | 12:17 PM
staticlude17's Avatar
The green circle is the fill plug and it is easier to use than removing the vss, but you have to use a sucksion gun/pump. (good invesment if you plan on doing your own fliuds!)
Old Jan 16, 2007 | 02:26 PM
invisible's Avatar
Default Re: Filling tranny fluid? (staticlude17)
added new picture. if that is the vss, how do i take it out? i already got the 10mm bolt out, but cant move it any where
Old Jan 16, 2007 | 03:06 PM
invisible's Avatar
well i pulled it out haha, so is that the vss???
Old Jan 16, 2007 | 03:16 PM
wiggle it back and forth, gently.
Old Jan 16, 2007 | 03:29 PM
invisible's Avatar
Default Re: (my_slow_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my_slow_civic &raquo;</TD></TR><TR><TD CLASS="quote">wiggle it back and forth, gently.</TD></TR></TABLE>
yeah i just got haha
Old Jan 16, 2007 | 03:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Huey &raquo;</TD></TR><TR><TD CLASS="quote">well i pulled it out haha, so is that the vss???</TD></TR></TABLE>
Vehicle Speed Sensor
controls the speedo
Old Jan 16, 2007 | 03:49 PM
allricedout's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by staticlude17 &raquo;</TD></TR><TR><TD CLASS="quote">The green circle is the fill plug and it is easier to use than removing the vss, but you have to use a sucksion gun/pump. (good invesment if you plan on doing your own fliuds!)</TD></TR></TABLE>
im looking into getting one also, is the squeeze(bulb) or pumping (like a bike pump) one better?
Old Jan 16, 2007 | 03:53 PM
Default Re: Filling tranny fluid? (allricedout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout &raquo;</TD></TR><TR><TD CLASS="quote">
im looking into getting one also, is the squeeze(bulb) or pumping (like a bike pump) one better?</TD></TR></TABLE>
I prefer the pump better. Only thing that sucks, is not every fluid bottle has the same size opening.
Old Jan 16, 2007 | 08:40 PM
yea i imagine if the hose for the pump is too big i would just have to cut the top off of the oil container
Old Jan 16, 2007 | 08:56 PM
fasthatchb18c1's Avatar
Id say your question has been answered but just in case don't tighten the bolt to the VSS to hard. I snapped the VSS mount when I fist put my back on
Old Mar 26, 2007 | 06:27 PM
Cyphear's Avatar
I prefer the pump better. Only thing that sucks, is not every fluid bottle has the same size opening.</TD></TR></TABLE>
Sorry to bring this back from the dead, but I just wanted to make everyone aware that I use a beerbong to pour the fluid in. It works great, just feed a couple foot tube down in there and pour it in the funnel. I'm sure everyone on H-T has a funnel and a few feet of tubing lying around. Unfortunately, it ruins a perfectly good beer bong.
Old Mar 26, 2007 | 07:34 PM
sauceja's Avatar
Default Re: Filling tranny fluid? (Cyphear)
You can also fill tranny through the vent cap. I have a hose that fits perfect so I use that.
Also it is important to open the fill plug so that when you are filling the tranny you know it is full when it starts to come out of the fill plug hole.
Just like an engine, too much fluid is not always good.
Old Mar 26, 2007 | 08:29 PM
eg8tuner's Avatar
Default Re: Filling tranny fluid? (.hue)
just out of curiosity what fluid does every one use?
Old Mar 26, 2007 | 09:08 PM
jumai182's Avatar
Default Re: Filling tranny fluid? (eg8tuner)
I use Royal Purple MTF. Kinda expensive but worth IMO.
MadCityLude
Aug 25, 2006 09:23 AM
ajwiant
Mar 4, 2006 08:33 PM
eL
10
Jan 30, 2005 04:02 PM
OTT
Mar 8, 2004 10:38 AM
fast+forward
Jan 19, 2004 02:03 PM
