Filling tranny fluid?
is this right. red is the drain plug, green the fill plug? also read you have to disconnect the VSS, where is that at?
is this the VSS?
Modified by .Huey at 5:24 PM 1/16/2007
is this the VSS?
Re: Filling tranny fluid? (.Huey)
Green plug. You do not need to disconnect the VSS to fill the fluid. Some people prefer to fill in through the VSS hole though.
Re: Filling tranny fluid? (my_slow_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my_slow_civic »</TD></TR><TR><TD CLASS="quote">Green plug. You do not need to disconnect the VSS to fill the fluid. Some people prefer to fill in through the VSS hole though.</TD></TR></TABLE>
so the green is the fill hole? do i just get a funnel and hose to pour it in?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Huey »</TD></TR><TR><TD CLASS="quote">
so the green is the fill hole? do i just get a funnel and hose to pour it in?</TD></TR></TABLE>
Yep. Or a pump that attaches to the fluid bottle.
filling via the vss hole is 100x easier
Its on top of the tranny, near the back.
Sticks straight up, about 3" tall with an electrical connector.
Remove one 10mm bolt, pull it straight up.
Pour in fluid
Pour in fluid
The green circle is the fill plug and it is easier to use than removing the vss, but you have to use a sucksion gun/pump. (good invesment if you plan on doing your own fliuds!)
Re: (my_slow_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my_slow_civic »</TD></TR><TR><TD CLASS="quote">wiggle it back and forth, gently.</TD></TR></TABLE>
yeah i just got haha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Huey »</TD></TR><TR><TD CLASS="quote">well i pulled it out haha, so is that the vss???</TD></TR></TABLE>
Vehicle Speed Sensor
controls the speedo
controls the speedo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by staticlude17 »</TD></TR><TR><TD CLASS="quote">The green circle is the fill plug and it is easier to use than removing the vss, but you have to use a sucksion gun/pump. (good invesment if you plan on doing your own fliuds!)</TD></TR></TABLE>
im looking into getting one also, is the squeeze(bulb) or pumping (like a bike pump) one better?
Re: Filling tranny fluid? (allricedout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout »</TD></TR><TR><TD CLASS="quote">
im looking into getting one also, is the squeeze(bulb) or pumping (like a bike pump) one better?</TD></TR></TABLE>
I prefer the pump better. Only thing that sucks, is not every fluid bottle has the same size opening.
Id say your question has been answered but just in case don't tighten the bolt to the VSS to hard. I snapped the VSS mount when I fist put my back on
I prefer the pump better. Only thing that sucks, is not every fluid bottle has the same size opening.</TD></TR></TABLE>
Sorry to bring this back from the dead, but I just wanted to make everyone aware that I use a beerbong to pour the fluid in. It works great, just feed a couple foot tube down in there and pour it in the funnel. I'm sure everyone on H-T has a funnel and a few feet of tubing lying around. Unfortunately, it ruins a perfectly good beer bong.
Re: Filling tranny fluid? (Cyphear)
You can also fill tranny through the vent cap. I have a hose that fits perfect so I use that.
Also it is important to open the fill plug so that when you are filling the tranny you know it is full when it starts to come out of the fill plug hole.
Just like an engine, too much fluid is not always good.
eL
10
01-30-2005 04:02 PM
