Changed main relay, still no magical "Click"......What next?
Old Jan 15, 2007 | 11:37 PM
joel4sale's Avatar
Default Changed main relay, still no magical "Click"......What next?
Got a 95 EG with B18 LS Swap. Car drives like a dream.
A month ago, have a little incident in the mall parking lot where car does not start for few hours. It was a very cold night and I had my heater blowing prior to the incident....after the car cools down 3 hours later, it starts fine. Had all the symptoms of failing main relay (got first click, and not the second or the third nor the fuel pump humming sound, crank but not start, CEL does not come for 2 sec). Car starts fine in the next month without problem.
Car does not start again today (cold day in the low 30s). I already got a brand new replacement main relay from Honda dealer handy. Replace the relay......Still no start....this time CEL stay on and does not go away. Did not hear the 2nd and third "Click".
Wha'ts the next logical guess?? ECU perhaps? Anyway to test my ECU?
Thanks in advance
Edit/Delete Message
Old Jan 16, 2007 | 12:16 AM
94VXLSHatchie's Avatar
Default Re: Changed main relay, still no magical "Click"......What next? (joel4sale)
have you checked the code for the CEL?
Old Jan 16, 2007 | 07:14 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: Changed main relay, still no magical "Click"......What next? (89crxsohcvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89crxsohcvtec &raquo;</TD></TR><TR><TD CLASS="quote">have you checked the code for the CEL?</TD></TR></TABLE>
Its not technically throwing a CEL, when the fuel pump doesn't prime and you turn the key to the "ON" position, the CEL stays on.
Maybe try another relay? Borrow one from a friends car and if that works, maybe somethings wrong with the wiring. If not, might be the fuel pump itself. I'm pretty sure there isn't a "fuel pump fuse" in 92-95 Civics. Could be wrong though.
If that doesn't work, check this out
https://honda-tech.com/zerothread?id=1320931
Old Jan 16, 2007 | 07:20 AM
Jimmy's Avatar
Global Moderator
If in fact it is your main relay, it's the joints in the relay.. Try tapping on the relay untill you hear the fuel pump prime..
Old Jan 16, 2007 | 07:22 AM
Luserkid's Avatar
Default Re: Changed main relay, still no magical "Click"......What next? (SkoundrelUSA)
Another thing i would recommend is checking the thermostat housing ground. Sand it down as well cause that could be a possibly cause if you already changed the MR
Old Jan 16, 2007 | 11:56 AM
93FlatBlackHatch's Avatar
I just fixed my car and it was doing the exact same thing. In my case it was the ecu. Get a mulitimeter and check the voltage at the map sensor with the key on. If it doesnt have 5 volts check pins d19(+) and d21(-) on your ecu plug for voltage. If you dont have any try another ecu. If thats not the problem check all of your fuses and grounds.
Old Jan 16, 2007 | 07:30 PM
joel4sale's Avatar
Thanks a lot guys, will do all those this weekend. Will start by checking CEL code and test ECU voltage. Hopefully it's just something simple.
Old Jan 17, 2007 | 01:52 AM
EJ1_203's Avatar
check all fuses again!
LS Turbo300
Oct 30, 2021 05:56 PM
HypL
Oct 5, 2012 01:31 PM
JDM_SOHC
19
Dec 20, 2011 04:15 PM
CiViC I2aCeI2
Jan 5, 2006 01:07 AM
illestrolla247
Jun 11, 2005 07:31 AM
