Changed main relay, still no magical "Click"......What next?
Old 01-15-2007, 11:37 PM
joel4sale's Avatar
Default Changed main relay, still no magical "Click"......What next?
Got a 95 EG with B18 LS Swap. Car drives like a dream.
A month ago, have a little incident in the mall parking lot where car does not start for few hours. It was a very cold night and I had my heater blowing prior to the incident....after the car cools down 3 hours later, it starts fine. Had all the symptoms of failing main relay (got first click, and not the second or the third nor the fuel pump humming sound, crank but not start, CEL does not come for 2 sec). Car starts fine in the next month without problem.
Car does not start again today (cold day in the low 30s). I already got a brand new replacement main relay from Honda dealer handy. Replace the relay......Still no start....this time CEL stay on and does not go away. Did not hear the 2nd and third "Click".
Wha'ts the next logical guess?? ECU perhaps? Anyway to test my ECU?
Thanks in advance
Edit/Delete Message
Old 01-16-2007, 12:16 AM
94VXLSHatchie's Avatar
Default Re: Changed main relay, still no magical "Click"......What next? (joel4sale)
have you checked the code for the CEL?
Old 01-16-2007, 07:14 AM
cute little bastard
SkoundrelUSA's Avatar
Default Re: Changed main relay, still no magical "Click"......What next? (89crxsohcvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89crxsohcvtec &raquo;</TD></TR><TR><TD CLASS="quote">have you checked the code for the CEL?</TD></TR></TABLE>
Its not technically throwing a CEL, when the fuel pump doesn't prime and you turn the key to the "ON" position, the CEL stays on.
Maybe try another relay? Borrow one from a friends car and if that works, maybe somethings wrong with the wiring. If not, might be the fuel pump itself. I'm pretty sure there isn't a "fuel pump fuse" in 92-95 Civics. Could be wrong though.
If that doesn't work, check this out
https://honda-tech.com/zerothread?id=1320931
Old 01-16-2007, 07:20 AM
Global Moderator
Jimmy's Avatar
If in fact it is your main relay, it's the joints in the relay.. Try tapping on the relay untill you hear the fuel pump prime..
Old 01-16-2007, 07:22 AM
Luserkid's Avatar
Default Re: Changed main relay, still no magical "Click"......What next? (SkoundrelUSA)
Another thing i would recommend is checking the thermostat housing ground. Sand it down as well cause that could be a possibly cause if you already changed the MR
Old 01-16-2007, 11:56 AM
93FlatBlackHatch's Avatar
I just fixed my car and it was doing the exact same thing. In my case it was the ecu. Get a mulitimeter and check the voltage at the map sensor with the key on. If it doesnt have 5 volts check pins d19(+) and d21(-) on your ecu plug for voltage. If you dont have any try another ecu. If thats not the problem check all of your fuses and grounds.
Old 01-16-2007, 07:30 PM
joel4sale's Avatar
Thanks a lot guys, will do all those this weekend. Will start by checking CEL code and test ECU voltage. Hopefully it's just something simple.
Old 01-17-2007, 01:52 AM
EJ1_203's Avatar
check all fuses again!
LS Turbo300
10-30-2021 05:56 PM
HypL
10-05-2012 01:31 PM
JDM_SOHC
19
12-20-2011 04:15 PM
CiViC I2aCeI2
01-05-2006 01:07 AM
illestrolla247
06-11-2005 07:31 AM
Quick Reply: Changed main relay, still no magical "Click"......What next?
