How do I remove oil pan studs?
Old Jan 15, 2007 | 11:11 AM
kracer's Avatar
Default How do I remove oil pan studs?
I tried searching but couldn't come up with anything. I bought this bare block and one of the studs was pretty bent and the treads didn't look that good either.
Old Jan 15, 2007 | 03:20 PM
bart2546's Avatar
Default Re: How do I remove oil pan studs? (kracer)
Well try to start small, maybe some vice grips if you can get them in a proper position, however other than that bolt-outs, as they're called, are available from sears at a reasonable small set price to a higher priced, better selection set.
Old Jan 16, 2007 | 03:17 PM
imptricer's Avatar
Default Re: How do I remove oil pan studs? (bart2546)
if the threads arents screwed up that bad try double nutting it
Old Jan 16, 2007 | 05:31 PM
Tchleung's Avatar
as said above. if the threads are not taht bad, try double nut trick. if they are bad, jsut force the nuts on. Either way, it's fubared. Or run a die over it and rethread it. then double nut it
Old Jan 16, 2007 | 07:50 PM
loudassVTEC's Avatar
Default Re: (Tchleung)
If its bent, you won't be able to restore the thread. Just use a pair of channelock pliers, or vice grips, and it'll unscrew like a bolt.
sk8shorty012
10
Mar 2, 2007 09:27 PM
TahitianEG
Sep 5, 2006 09:41 AM
linx
Jun 16, 2003 09:15 PM
turbohf
Feb 16, 2003 10:20 PM
TheShad0w
Jul 2, 2001 10:16 AM
