Cam seal question. Lube the new one up or not??
Old Jan 14, 2007 | 04:54 PM
EJ1 wilcox's Avatar
Default Cam seal question. Lube the new one up or not??
Just a quick question.
I know my old cam seal was leaking, so I picked up a new one and installed it. All I did was remove the valve cover, then the upper timing belt cover.
Then I removed the cam sprocket and pulled the old oil seal out. Then I lubed the new seal up with some fresh oil, and pushed it into place, then I put the cam gear back on, etc etc etc.
I started my car and when I turned it off I found a large puddle of oil under that side of the motor! ****!!
So it was a little leak before, now it's a much larger leak. Is there any trick to installing that cam seal? Or what? Just lube it up and push it in right? lol
This is a d16z6 by the way.
Old Jan 14, 2007 | 05:36 PM
schardbody's Avatar
yes, did you get it in square???
Old Jan 14, 2007 | 07:54 PM
EJ1 wilcox's Avatar
Default Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">yes, did you get it in square???</TD></TR></TABLE>
Yup. I made sure to get it all the way in.
I'm thinking if it's still leaking tomorrow I might pull the VC and the cam gear back off of there and check to make sure everything is cool.
EdGe(161)
Apr 11, 2011 09:28 AM
endlssmystry
Jan 24, 2010 08:11 PM
MR Rodgers
Jun 26, 2007 09:46 PM
hondatuner20
13
Mar 4, 2006 06:38 PM
DAintegraGSR
May 21, 2005 06:06 PM
