Can't get the bolt out for the alternator?
Old Jan 14, 2007 | 02:53 PM
94b16teg's Avatar
Default Can't get the bolt out for the alternator?
The adjuster bolt was not a problem but the other one is not being cool. I got the nut of but I cant get the stud out Ive hit it with a hammer and it wont move. What should I do? The car is a 90 CRX Si. Thanks Justin
Old Jan 14, 2007 | 03:18 PM
JJ's civic's Avatar
Default Re: Can't get the bolt out for the alternator? (94b16teg)
i had the same prob i ended up taking it to a shop and all they did was used a bigger hammer and a medal rod. si i say get a bigger hammer lol
Old Jan 14, 2007 | 05:09 PM
highroller54's Avatar
Default Re: Can't get the bolt out for the alternator? (JJ's civic)
hold your moms purse so she can have a go at it.
Old Jan 14, 2007 | 06:29 PM
Rex-Si's Avatar
Default Re: Can't get the bolt out for the alternator? (highroller54)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highroller54 &raquo;</TD></TR><TR><TD CLASS="quote">hold your moms purse so she can have a go at it.</TD></TR></TABLE>
Owned !
Old Jan 14, 2007 | 06:35 PM
betsy84's Avatar
He's right though, dont be a ***** just get a long standard tip screw driver and hammer and give'r. If it's on the ground lcok the wheels all the way to the left. To get the alt out you'll have to snake it over to the passenger side of the compartment apparently.
Old Jan 14, 2007 | 07:08 PM
higgunscrx's Avatar
leave the nut on it but loosend almost all the way off. and get a bfh (big ****** hammer) and go at it. my 86 civic gave me some problems until i got my bfh out.
Old Jan 14, 2007 | 07:12 PM
si_zc_civic's Avatar
Default Re: (higgunscrx)
mine took a torch, a 5 pound sledge and a prybar. all at once.
Old Jan 14, 2007 | 08:38 PM
Pee Wee's Avatar
Default Re: (si_zc_civic)
long *** cheater bar ftw
Old Jan 16, 2007 | 04:47 AM
Hondaisok's Avatar
Default Re: (Pee Wee)
Had same problem. I unbolted the bracket from the engine, 2 bolts if I remember correctly. Then once it is outside of the car, you can use the BFH more effectively. I slathered anti-seize all over that bolt when I put it back in.
mr darcko
Jun 30, 2024 02:00 PM
bsivoljr
Jun 23, 2009 09:14 PM
civicEXtreme
Suspension & Brakes
Feb 22, 2006 02:36 PM
Sanyo
Jul 25, 2005 10:27 AM
Unjockable
14
Feb 18, 2005 05:52 PM
