My H23A1 wont start!
Old Jan 14, 2007 | 11:00 AM
Auby's Avatar
Default My H23A1 wont start!
So I just rebuilt a H23A1 for my 92 Honda Prelude and put it in the car and it won’t start. I have checked everything I can think of. It has spark and it has fuel. I just can’t figure it out. It acts as if it wants to engage but it doesn’t. The only thing that I can think of is that the Gas is bad. It has been sitting for almost a year. Could that be the problem? I mean it would be old and not as rich as it should be. PLASE HELP!!!
Thanks
Old Jan 14, 2007 | 11:17 AM
preludeguy_92's Avatar
Default Re: My H23A1 wont start! (Auby)
My guess is that your timing is off.
Old Jan 14, 2007 | 11:21 AM
Hawkze_2.3's Avatar
So it cranks and it just won't start?
Definately double check timing and make sure you have spark at the plugs.
Old Jan 14, 2007 | 11:29 AM
Auby's Avatar
Yes it cranks and won’t start. I keep trying to retard the timing. I move the distributor back and forth and it gets better then it goes back to where it was. I also have checked the sparkplugs like 3 times. They also are in the right firing order.
Old Jan 14, 2007 | 12:15 PM
xthekidx's Avatar
Default Re: (Auby)
i would take it so a person that can hook it up to a computer to see whats wrong with the ECU or timing. someone you know has to have a computer.
Old Jan 14, 2007 | 12:25 PM
Default Re: (xthekidx)
have you checked your cam timing
Old Jan 14, 2007 | 02:54 PM
Auby's Avatar
How do I check the cam timing? I dont know how to time it. Its at my dads I was going to take it someplace to have it timed. Shouldnt it start even though its not timed? I dont know maybe I am dumb.
Old Jan 14, 2007 | 03:02 PM
Default Re: (Auby)
To see if it is timed put the #1 cylinder at tdc then make sure the arrows on the cam gears point up.
And yes that can keep it from starting.
Old Jan 14, 2007 | 03:04 PM
Hawkze_2.3's Avatar
Default Re: (Auby)
OMG, you rebuilt it and you don't know how to time it? How did you put the head back on without setting the timing?!
It very well may not start without being timed, and even worse if it's far off you will bend the valves. Get a manual or search this website and you'll find out how to set the timing with the cam gears and flywheel marks.
Old Jan 14, 2007 | 03:05 PM
Auby's Avatar
Ok I will do.
Old Jan 14, 2007 | 03:13 PM
Auby's Avatar
Like I said I am dumb. This is the first car that really worked on. So it a learning process for me, I just hope that they don’t bend. I had the head work done someplace else and my dad put the head on the block and put it in the car. It at his house cause he has all the tools. It hard for me to make it to his house because I work 3 jobs and he lives like an hour and a half away.
Old Jan 14, 2007 | 04:02 PM
Hawkze_2.3's Avatar
Default Re: (Auby)
So does your dad know about Hondas? When I used to work on my car in the parents garage my dad would ask me about my lifters
Old Jan 16, 2007 | 07:08 PM
Auby's Avatar
He knows about cars. He hates hondas. He said the he would die and go to hell befor he likes Hondas. I talk to him and he did set the piston with the cams.
Old Jan 16, 2007 | 08:46 PM
Hawkze_2.3's Avatar
Default Re: (Auby)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Auby &raquo;</TD></TR><TR><TD CLASS="quote">He knows about cars. He hates hondas. He said the he would die and go to hell befor he likes Hondas. I talk to him and he did set the piston with the cams.</TD></TR></TABLE>
He needs to use the marks on the flywheel to set the cam timing and ignition timing.
Old Jan 16, 2007 | 09:04 PM
SUB-0 H23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Auby &raquo;</TD></TR><TR><TD CLASS="quote"> So I just rebuilt a H23A1 for my 92 Honda Prelude and put it in the car and it won’t start. I have checked everything I can think of. It has spark and it has fuel. I just can’t figure it out. It acts as if it wants to engage but it doesn’t. The only thing that I can think of is that the Gas is bad. It has been sitting for almost a year. Could that be the problem? I mean it would be old and not as rich as it should be. PLASE HELP!!!
Thanks
that is your answer right thur
Old Jan 17, 2007 | 07:47 AM
VtecFreePrelude's Avatar
Default Re: (SUB-0 H23)
and there's an easy way to check that!!!
Old Jan 18, 2007 | 07:26 AM
Auby's Avatar
OK thanks will let him know. Its so hard to say this is what needs do be done. He is like a little butterfly, so fragle. He get upset and is like you dont think I can do this your talk to other people. Hes crazy. But i will tell him because it needs to be done!
yo bj
Feb 2, 2011 05:54 PM
EJ ITO
26
Mar 22, 2007 05:41 AM
CodyC142
Nov 1, 2006 07:08 AM
turboblkek
Sep 7, 2005 04:05 PM
pbizzlegsr
Jul 7, 2004 10:23 PM
