help me pick a HO alternator
Old Jan 13, 2007 | 11:38 PM
xluben's Avatar
Default help me pick a HO alternator
i'm on a tight budget, but need a HO alternator to support my amplifier.
i'll be running approximately 1600W RMS.
my car is a 99 honda accord 2.3L I4, it comes stock with an 80 amp alternator.
i'm looking at one on ebay for $120 shipped that does 130 amps. it comes with a 90 day warranty.
or this one: http://verizonsupersite.com/4a...10013
which does 150 amps and costs $250. it comes with a lifetime warranty.
that's a HUGE difference in price.
i really do like the lifetime warranty, but cost is a main concern.
i also realize that 130 amps probably really isn't enough (150 might not even be enough), but this is really all my budget will allow.
which one do you think i should go with?
also, this will be with the stock battery. i'll try and put a deep cycle under the hood if my budget will allow (in the future).
Old Jan 13, 2007 | 11:51 PM
sony224422's Avatar
Default Re: help me pick a HO alternator (xluben)
check ebay. they usually have some good deals.. just make sure its a lifetime warranty
Old Jan 14, 2007 | 12:01 AM
xluben's Avatar
Default Re: help me pick a HO alternator (sony224422)
only found a few. some refurb's (80 amp), 130 amp for $120, and a few from iraggi (200 amp for $300 seems like a good deal, if only i had the money).
Old Jan 14, 2007 | 04:27 PM
steerh67's Avatar
i know this is not what you're going to hear, because i'm sure you're eager to get one and put it in. the best advice i can give you though is to shop around...i mean really do some research. it will mean you'll have to wait a little while longer, but by then you'll have saved a little money, and can be sure that you got the best product you could. there is nothing worse than buying something in a hurry only to discover that it wasnt as good as you thought it was going to be. a lot of parts stores can get you high output alternators as well, you just have to ask them. chances are out of laziness they'll tell you they can't, so when you ask, make sure you're talking to a manager or somebody you're familiar with. by buying one locally you're also saving yourself a great deal of down time should something go wrong.
Old Jan 14, 2007 | 09:06 PM
AJ06's Avatar
Default Re: help me pick a HO alternator (steerh67)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steerh67 &raquo;</TD></TR><TR><TD CLASS="quote">i know this is not what you're going to hear, because i'm sure you're eager to get one and put it in. the best advice i can give you though is to shop around...i mean really do some research. it will mean you'll have to wait a little while longer, but by then you'll have saved a little money, and can be sure that you got the best product you could. there is nothing worse than buying something in a hurry only to discover that it wasnt as good as you thought it was going to be. a lot of parts stores can get you high output alternators as well, you just have to ask them. chances are out of laziness they'll tell you they can't, so when you ask, make sure you're talking to a manager or somebody you're familiar with. by buying one locally you're also saving yourself a great deal of down time should something go wrong. </TD></TR></TABLE>
He knows what he's talkin about...
I ahve EA and its not bad, just the voltage dropps a little too much for my taste
Old Jan 14, 2007 | 09:35 PM
xluben's Avatar
Default Re: help me pick a HO alternator (AJ06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AJ06 &raquo;</TD></TR><TR><TD CLASS="quote">
I ahve EA and its not bad, just the voltage dropps a little too much for my taste</TD></TR></TABLE>
how many watts is your setup?
how many amps is your alt?
it looks like a may just get the cheap one.
Old Jan 16, 2007 | 09:12 PM
AJ06's Avatar
I have 1200 watts on type R's and a 200 watt amp 4 channel
soo 1400 watts
AND my alt is 200 amp alt
Old Jan 17, 2007 | 05:12 AM
xluben's Avatar
Default Re: (AJ06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AJ06 &raquo;</TD></TR><TR><TD CLASS="quote">I have 1200 watts on type R's and a 200 watt amp 4 channel
soo 1400 watts
AND my alt is 200 amp alt</TD></TR></TABLE>
which alt?
Old Jan 17, 2007 | 08:28 AM
AJ06's Avatar
the EA one... IT does good, it doesnt dim above 900 rmp...
Below that its a very different story, Im practically running on battery if the rmp's are at 600-700 idle with everything [AC/lights/stereo]
tim_r95
Jan 27, 2015 08:02 AM
deerman2701
Oct 22, 2008 02:57 PM
honda95civic
Audio / Security / Video
12
Jun 10, 2006 02:00 PM
icculus723
May 12, 2004 08:39 AM
accord94
Mar 6, 2003 02:05 PM
