B18C won't start
Old Jan 13, 2007 | 04:15 PM
handa's Avatar
Default B18C won't start
Just got done putting a B18C motor (obd2) on a Honda Civic DX Coupe (EJ1), but it won't start! It will just crank, but won't start! TDC, firing order, sparks, and fuel all checks out fine. We also tested the injectors and they squirt in 1-3-4-2 order just fine.
Here is what we are using:
-obd2 b18c (itr) 98+ spec motor
-obd2 injectors (from motor; clip wires cut and rewired into the dx harness)
-obd1 harness civic dx
-obd1 ecu p28 (skunk2 chipped)
-obd1 distributor b16
Any ideas?
Modified by handa at 10:38 PM 1/13/2007
Old Jan 13, 2007 | 06:11 PM
handa's Avatar
Default Re: B18C won't start (handa)
Also added more ground wires to the "thermostat housing"...no luck. anybody?
Old Jan 13, 2007 | 06:17 PM
sicones's Avatar
what B18C, GSR or R? and that "P28" needs to be chipped...
Old Jan 13, 2007 | 06:19 PM
StreetRacinThug's Avatar
Hmmmm....sounds like you did fine with matching what you need. This is the first post I read where OP used original Harness on motor. So im stumped. My first guess is grounds. Thermo, Valve, Trans. Could be the dizzy is no good.
Check for spark.
Old Jan 13, 2007 | 06:20 PM
Im more than sure his P28 is chipped if not that is a high possibility thats the problem.
Old Jan 13, 2007 | 07:34 PM
handa's Avatar
Default Re: (StreetRacinThug)
Sorry I forgot about that, it is a B18C (Type-R) with Skunk2 Chipped P28 ecu. I'll give a try on a different distributor.
Old Jan 13, 2007 | 07:38 PM
Syndacate's Avatar
Default Re: (handa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by handa &raquo;</TD></TR><TR><TD CLASS="quote">Sorry I forgot about that, it is a B18C (Type-R) with Skunk2 Chipped P28 ecu. I'll give a try on a different distributor.</TD></TR></TABLE>
That's what you'll have to do.
You said you checked the fuel? Did you check it by measuring the fuel pressure off of a T at the fuel rail? If not, do it that way.
Weird ****, if you grounded the plugs and the spark is jumping it should be fine. Sounds like it must be a fuel issue.
Old Jan 13, 2007 | 07:51 PM
handa's Avatar
Default Re: (Syndacate)
I checked the fuel by a really "ghetto" way lol. I took out the fuel rail and tied all the injectors with it in their rightful seats, cranked the motor, and observe the fuel squirting in their patterns into a bucket. I'll probably buy a fuel gauge and check its pressure. Thanks!
Old Jan 13, 2007 | 07:52 PM
Eran's Avatar
HT White Ops
Default Re: (handa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by handa &raquo;</TD></TR><TR><TD CLASS="quote">I checked the fuel by a really "ghetto" way lol. I took out the fuel rail and tied all the injectors with it in their rightful seats, cranked the motor, and observe the fuel squirting in their patterns into a bucket. I'll probably buy a fuel gauge and check its pressure. Thanks!</TD></TR></TABLE>
That is really ghetto
Old Jan 13, 2007 | 08:02 PM
deadline's Avatar
Default Re: (handa)
its like milkin a COW....lol
Old Jan 13, 2007 | 09:11 PM
Syndacate's Avatar
Default Re: (deadline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadline &raquo;</TD></TR><TR><TD CLASS="quote">
its like milkin a COW....lol </TD></TR></TABLE>
lmao
Old Jan 14, 2007 | 09:37 AM
Well if it is shooting fuel then that is not the problem. Is fuel returning? Remove the hose from FPR and have someone look while cranking and it should wait shoot wait shoot if it does then I would say forget about the fuel problem and look into spark. I know sometimes fuses can cause the car not to start.
Old Jan 14, 2007 | 12:19 PM
aznej2's Avatar
update: changed spark plugs and new wires.... car starts! but idles like a tractor and is very shaky... any ideas ? (im the guy who owns the car)
Old Jan 14, 2007 | 01:14 PM
Rocks03's Avatar
Default Re: (aznej2)
Check your ignition timing. That can smooth it out. Also check for codes and see if any of your sensors are bad.
Old Jan 14, 2007 | 07:31 PM
aznej2's Avatar
Default Re: (Rocks03)
got it running! lil playing wit the tps distributor and idle screw
freedomsk8ers
Jan 18, 2015 08:17 AM
Unomi
Mar 15, 2012 05:48 PM
ek9beast562
52
Nov 19, 2011 04:35 PM
oXeNo
Jul 24, 2011 02:20 PM
ryn1973
13
Apr 11, 2002 05:44 AM
