using a s100 to run individual throttle bodies
Old Jan 13, 2007 | 09:33 AM
ITRtist's Avatar
Default using a s100 to run individual throttle bodies
I was told by an unreliable source that using an hondata s100 when tuning a motor with ITB's would have unsuccessful results, i would like to know if this is true.
i would appreciate if a knowledgeable person would shed some light on this situation-thanx
Old Jan 13, 2007 | 11:09 AM
92TypeR's Avatar
FSAE
Default Re: using a s100 to run individual throttle bodies (ITRtist)
S100 does not offer Alpha-N or TPS/MAP tuning capabilities, so tuning partial throttle will be difficult, and only a good tuner with experience tuning ITB's solely off MAP will achieve normal driveability.
Old Jan 13, 2007 | 12:07 PM
j spec's Avatar
Default Re: using a s100 to run individual throttle bodies (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">S100 does not offer Alpha-N or TPS/MAP tuning capabilities, so tuning partial throttle will be difficult, and only a good tuner with experience tuning ITB's solely off MAP will achieve normal driveability.</TD></TR></TABLE>
precisely!
s300 offers tuning capabilities for what you need to tune itb's
Old Jan 13, 2007 | 04:43 PM
dblock2x's Avatar
what is the difference between the option crome pro has for itbs and the s300? i am lookin to run some itbs myself
Old Jan 13, 2007 | 04:50 PM
92TypeR's Avatar
FSAE
Default Re: (cooper.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cooper. &raquo;</TD></TR><TR><TD CLASS="quote">what is the difference between the option crome pro has for itbs and the s300? i am lookin to run some itbs myself</TD></TR></TABLE>
Same thing. TPS/MAP vs RPM and TPS vs RPM options. Plus you have the ability to scale your TPS voltage to match that of the throttlebodies.
Old Jan 13, 2007 | 05:06 PM
mgags7's Avatar
the s300 sucks compared to the others that allow TPS tuning though.....go with crome or AEM if you can afford that.....
Old Jan 14, 2007 | 07:14 AM
j spec's Avatar
Default Re: (bb4ever)
the ability to scale the tps voltage would definitely be a plus to help with tuning. and crome offers this, also the price differences should definitely be taken into consideration. aem~1000 s300~550 crome software is free to my understanding
Old Jan 14, 2007 | 07:28 AM
98vtec's Avatar
moderator emeritus
Default Re: (j spec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j spec &raquo;</TD></TR><TR><TD CLASS="quote">the ability to scale the tps voltage would definitely be a plus to help with tuning. and crome offers this, also the price differences should definitely be taken into consideration. aem~1000 s300~550 crome software is free to my understanding</TD></TR></TABLE>
i would HIGHLY suggest going with Crome Pro to tune ITB's. Without Pro, your going to be battling with your motor trying to get closed loop right.
bluenc-87
Engine Management and Tuning
Aug 22, 2015 01:53 AM
GABOCRX
Jan 13, 2011 04:49 AM
boostincoupe
Sep 3, 2005 01:54 PM
ceemarun
Jun 26, 2002 12:07 PM
