Blower Motor Only Works On Setting 3 & 4?
Old Jan 12, 2007 | 07:50 AM
dr_latino999's Avatar
Default Blower Motor Only Works On Setting 3 & 4?
My blower just suddenly started behaving like this -
OFF - OFF
1 - OFF
2 - OFF
3 - 3
4 - 4
The first two settings do nothing at all, and the 3rd and 4th work as normal. Am I correct in assuming that I need to replace number 5 in the parts diagram?
Part Number - 79330-SH3-003
Item - RESISTOR, BLOWER
Price - 22.26
REFERENCE https://honda-tech.com/zerothread?id=725462
Old Jan 12, 2007 | 08:01 AM
B16-CRX's Avatar
Yea, thats the blower motor resistor. Most likely your problem.
Old Jan 12, 2007 | 08:09 AM
ILcrxsi1's Avatar
I tell doctors what to do
Default Re: (B16-CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16-CRX &raquo;</TD></TR><TR><TD CLASS="quote">Yea, thats the blower motor resistor. Most likely your problem.</TD></TR></TABLE>yep, that's it
Default Re: (ILcrxsi1)
10.4 guys, thanks for the quick replies This is another reason why my car will never be fast, I spend all my money on fixing little things
Old Jan 12, 2007 | 08:17 AM
Got_soy's Avatar
Default Re: (dr_latino999)
same thing happend to me, still only 3 and 4
Old Jan 12, 2007 | 08:18 AM
Default Re: (Got_soy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy &raquo;</TD></TR><TR><TD CLASS="quote"> same thing happend to me, still only 3 and 4</TD></TR></TABLE> Do you mean you replaced the Resistor and settings 1 and 2 still didn't work?
Old Jan 12, 2007 | 08:21 AM
Got_soy's Avatar
I just never got around to changing the resistors
Old Jan 12, 2007 | 09:33 AM
ILcrxsi1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy &raquo;</TD></TR><TR><TD CLASS="quote">I just never got around to changing the resistors </TD></TR></TABLE>I probably wouldn't bother fixing it either.
Old Jan 12, 2007 | 09:36 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 &raquo;</TD></TR><TR><TD CLASS="quote">I probably wouldn't bother fixing it either. </TD></TR></TABLE> Well I am going to bother fixing it because sometimes I just want a wee bit of heat, not a massive blast of Saharan air. And I can't stand things not working the way they are supposed to
Old Jan 12, 2007 | 09:37 AM
ILcrxsi1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> Well I am going to bother fixing it because sometimes I just want a wee bit of heat, not a massive blast of Saharan air. And I can't stand things not working the way they are supposed to </TD></TR></TABLE>tell me about it. in the fall I take the center console apart and pull the wires to heat and in the spring I do it again and set it to cold.
Old Jan 12, 2007 | 11:30 AM
wiZCo's Avatar
Stouts 'n' Scotch
You may be able to luck out and get one as a pocket score from a junkyard. If you're pulling used ones, just compare your bad one to them, you'll see which ones are good very easily. Otherwise I think they're ~$25 from Majestic. Or if you're patient, I put a WTB for one in my sig and got one from a member here after three weeks or so.
Old Jan 12, 2007 | 05:40 PM
Default Re: (wiZCo)
I'm 100% going to get one new so I don't have to worry about it for another 17 years
gwoolfall
Honda Civic (2001 - 2005)
Sep 15, 2013 09:10 AM
tealej2
Apr 15, 2013 10:08 AM
wteebo
Jan 12, 2013 03:27 PM
Red_ED8
Sep 7, 2010 09:20 AM
MEBHB91EF9
Sep 16, 2008 07:52 PM
