car wont start!!!
Old Jan 12, 2007 | 06:34 AM
bigl1986's Avatar
Default car wont start!!!
i have a swapped b16a into a 95 civic lx four door. the problem is when i turn the car to start, the motor doesnt crank. the electronics in the car turn on but not the motor. the speedo jumps twice to 65mph and sticks there. i checked all fuses and power connections...what can it be????
Old Jan 12, 2007 | 07:12 AM
Otherguy's Avatar
NASIOC.com
Default Re: car wont start!!! (bigl1986)
Check your grounds, and double check all your wiring
Old Jan 12, 2007 | 08:07 AM
bigl1986's Avatar
Default Re: car wont start!!! (Otherguy)
did all that. i work on car sound systems and i know alot on wiring. all the grounds are good still no power to motor
Old Jan 12, 2007 | 08:18 AM
Hybrid-Fusion's Avatar
Follow the wiring back to the starter. If you want to cheat, turn the car to on, PUT IT IN NEUTRAL, and take a wire and run it from the + on the battery and touch the Signal "tab" on the solenoid.
Old Jan 12, 2007 | 11:43 AM
bigl1986's Avatar
Default Re: car wont start!!! (Hybrid-Fusion)
if ive had problems with the dizzy before, could that be the problem? i have a modafied NON VTEC dizzy on there right now from a B20. the thing has like 15000 miles on it. could that be a factor?
Old Jan 12, 2007 | 11:46 AM
fmrprojects's Avatar
do you even get a crank, or nothing at all. if nothing, check if the groung on the therostat housing is hooked up. thats the ground for the ecu. is the starter hooked up and is the motor getting spark
Old Jan 12, 2007 | 12:00 PM
gezzuzz's Avatar
Default Re: car wont start!!! (fmrprojects)
does the starter come on? if not check the little wire that goes to it..
the you got clutch switch...
starting relay..
Old Jan 16, 2007 | 05:46 AM
bigl1986's Avatar
Default Re: car wont start!!! (gezzuzz)
it was the damn starter...that piece of s@#t. thanks man
si-lude4evr
Mar 7, 2012 09:37 PM
raidacaipo
May 19, 2008 02:54 PM
perseverance
Nov 21, 2007 05:55 PM
ludetrouble
Mar 31, 2007 04:31 PM
TeamCracka
Sep 16, 2005 08:21 AM
