D15b2 bad - D15b7 long block using b2 dpfi, etc???
My d15b2 is junk. I can get d15b7 block pretty easily. Can I use a D15b7 long block with all of the b2 stuff on it? I am pretty sure this should work but am not sure.
Thanks,
Aaron
Thanks,
Aaron
yes,,use the old intake manifold,exhaust manifold,distributor,ecu,etc..and it will run fine...Not sure about the coolant hoses though,they might need to be changed
also you need to extend your fan switch wires then solder on a different plug that will work with the d15b7
So the dizzy bolt pattern is the same for both motors? I know some of the d15's vary on what dizzy they need. Just wanna make sure the B2 dizzy will work on the d15b7.
It may just be the vtec D series dizzys that are different though.
Thanks for any help.
only the d16z6 vtec head has the weird distributor..as well as the other jdm equivalent heads like the d15b vtec, or sohc vtec zc,etc,etc,etc..you get the point
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.speaker »</TD></TR><TR><TD CLASS="quote">only the d16z6 vtec head has the weird distributor..as well as the other jdm equivalent heads like the d15b vtec, or sohc vtec zc,etc,etc,etc..you get the point</TD></TR></TABLE>
Ok thanks. I must have remembered that from swapping a JDM d15b into my EG a couple years ago.
i did this exact swap, d15b7 when i blew my b2. perfect fit didnt have to modify anything. i just put the fan switch on the b7 from the b2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller »</TD></TR><TR><TD CLASS="quote">i did this exact swap, d15b7 when i blew my b2. perfect fit didnt have to modify anything. i just put the fan switch on the b7 from the b2</TD></TR></TABLE>
Awesome! Thanks.
Awesome! Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.speaker »</TD></TR><TR><TD CLASS="quote">Not sure about the coolant hoses though,they might need to be changed</TD></TR></TABLE>
they are the same, only the z6 has diff coolent tubes...
bobbyg crxh22
Nov 5, 2006 12:55 PM
