Enough Mods To Need a Tune?
Old Jan 11, 2007 | 06:33 PM
allnaturalb16's Avatar
Default Enough Mods To Need a Tune?
Motor Starts Up on tuesday I wanted to know if it imperative that i go get a tune first or is this setup mild enough to not warrant a tune? maybe a kenji basemap or even stock ecu?
B16a: New crank, Eagle Rods, Probe 11:1.1 CR pistons
Stock Gsr Head w/S2 valves and springs
JDM Itr headers, straight pipe exhaust, AEBS intake mani, S2 throttle body, Bigger fuel rail, and 270 RC injectors
Old Jan 11, 2007 | 08:32 PM
RedEj8's Avatar
Default Re: Enough Mods To Need a Tune? (allnaturalb16)
Must be tuned. With the higher compression and more airflow..its a must..Especially if this was a B16 stock b16 basemap that it was running on before the build.
Old Jan 11, 2007 | 08:34 PM
ABK's Avatar
ABK
Default Re: Enough Mods To Need a Tune? (RedEj8)
yea defently needs a tune.
Old Jan 12, 2007 | 12:15 AM
Richard...'s Avatar
Default Re: Enough Mods To Need a Tune? (ABK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allnaturalb16 &raquo;</TD></TR><TR><TD CLASS="quote">Motor Starts Up on tuesday I wanted to know if it imperative that i go get a tune first or is this setup mild enough to not warrant a tune? maybe a kenji basemap or even stock ecu?
JDM Itr headers, straight pipe exhaust, AEBS intake mani, S2 throttle body, Bigger fuel rail, and 270 RC injectors</TD></TR></TABLE>
any time you change the setup from what the factory tuned it to be to get your moneys worth or the max of what you change then you need to tune also need to tune depending on what you do to the motor for the safty of the motor
Old Jan 12, 2007 | 09:13 AM
Jay_Sensing's Avatar
Most definately (as if you need anymore confirmation), you are dealing more compression, larger injectors, and improved overall flow so although it will probably crank, idle, and maybe even drive "ok", you will neither know if you are safe or dangerously lean not to mention you are not getting your money's worth out of the parts you installed.
If you just wanted to crank it and maybe baby it to a dyno or a local tuner, then yeah, I personally would do that but once again, that will vary from person to person on what they are willing to do as well.
Old Jan 12, 2007 | 11:36 AM
Default Re: (Jay_Sensing)
any good tuners in the 909 area code? and what do i need to tune just a/f?
Old Jan 12, 2007 | 12:09 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (allnaturalb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allnaturalb16 &raquo;</TD></TR><TR><TD CLASS="quote">any good tuners in the 909 area code? and what do i need to tune just a/f?</TD></TR></TABLE>
AND ignition timing.
Old Jan 12, 2007 | 01:46 PM
vtec2nv's Avatar
hey this is my motto, anytime you mod you need a tune. to get the MOST power out of any mod. get it tuned goodluck with the car also let us know what kind of whp u put dwn.
Old Jan 12, 2007 | 04:25 PM
Richard...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay_Sensing &raquo;</TD></TR><TR><TD CLASS="quote">Most definately (as if you need anymore confirmation), you are dealing more compression, larger injectors, and improved overall flow so although it will probably crank, idle, and maybe even drive "ok", you will neither know if you are safe or dangerously lean not to mention you are not getting your money's worth out of the parts you installed.
If you just wanted to crank it and maybe baby it to a dyno or a local tuner, then yeah, I personally would do that but once again, that will vary from person to person on what they are willing to do as well.</TD></TR></TABLE>
well for babying your car down to the dyno shop you could always turn down the timing and turn up the fuel of you have a fuel pressure reg to make sure your not going to hurt your car down to the dyno shop
as for what you need to tune your car well in the strictest sense of the matter that depends on the tuner most will do it from a dyno
BUT there are some who will only tune your car on the street/drag strip because there argument is that real world driving conditions are not simulated but best results for your needs are produced in real time driving conditions!
Old Jan 12, 2007 | 05:08 PM
Darkane's Avatar
Default Re: (richard7968)
Rc 270 injectors wont run to good unless tuned. It wont be to bad probably but get it tuned as said before
Old Jan 12, 2007 | 06:57 PM
integrawow's Avatar
Just curious, where did you purchase the 270cc injectors from?
Old Jan 12, 2007 | 08:27 PM
Fezzie's Avatar
tune is a MUST!!!!
Old Jan 12, 2007 | 11:25 PM
Richard...'s Avatar
Default Re: (Darkane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darkane &raquo;</TD></TR><TR><TD CLASS="quote">Rc 270 injectors wont run to good unless tuned. It wont be to bad probably but get it tuned as said before
rc can make any CC injector you think you might need for your setup!
Old Jan 13, 2007 | 01:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrawow &raquo;</TD></TR><TR><TD CLASS="quote">Just curious, where did you purchase the 270cc injectors from?</TD></TR></TABLE>
right here on honda tech i forget the users name.... naturalaspirations or something
Old Jan 13, 2007 | 01:39 PM
Richard...'s Avatar
prelude arnt they around that flow rate too?
Old Jan 13, 2007 | 01:56 PM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richard7968 &raquo;</TD></TR><TR><TD CLASS="quote">
prelude arnt they around that flow rate too?</TD></TR></TABLE>
Preludes are 290cc stock
mrx
Feb 15, 2021 03:33 AM
Nurburgring
Feb 5, 2017 04:03 PM
streetsold6teeny8
19
Jan 24, 2010 05:38 AM
mugenhatchie
Dec 5, 2005 05:38 AM
964dgsr
Jul 24, 2003 10:37 PM
