Injector Question???
i have a 93 civic ex and im putting in 550cc injectors and want to know is there anything special i need to know or do when putting in injectors they come with all the hardware needed to install them. so hopefully its not gunna be to bad ( we all know hondas ) haha
jared
jared
i have checked into that already i have the right injectors high imedance and i was told that the only thing ill have to upgrade will be the fuel pump everything esle can stay stock like the rail and the regulator im only gunna run 15lbs any way
well my car is a 93 civic ex D16z6 turbo is a t3 t4 hybird i have complete MSD setup VAFC-2 lightend flywheel and stage 2 clutch and now to be putting in 550cc injector and running 15lbs boost i have built the bottow end rods pistons and crank the head is stock and i think thats all to the motor i think!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jarven93 »</TD></TR><TR><TD CLASS="quote">i was told by a few guys on this site that i could run 15lbs. unsleeved in not whats the most you guys recomend???</TD></TR></TABLE>
8 daily, 10-12 track maybe .... other people have other opinions, but I bank on the side of safety unless you have a rather mild and bulletproof tune.
Guest
Posts: n/a
not to jack the thread or anything, i'm just reading and learning, and instead of opening a new thread to ask what maybe be a simple question i'll ask here.
By sleeving, you just mean replacing the sleeves? or does the d16 use a parent block where you recomend boring and sleeving?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowCivic29 »</TD></TR><TR><TD CLASS="quote">not to jack the thread or anything, i'm just reading and learning, and instead of opening a new thread to ask what maybe be a simple question i'll ask here.
By sleeving, you just mean replacing the sleeves? or does the d16 use a parent block where you recomend boring and sleeving?</TD></TR></TABLE>
cut the old sleeves out. replace with new ductile iron sleeves.
