How to identify cause of window falling off track in an EK?
Old Jan 11, 2007 | 07:53 AM
EJ8chu's Avatar
Default How to identify cause of window falling off track in an EK?
Look i know this is a tired *** topic and bazzilions of people have had the same problem. It seems that some cases are worse than others. Ive searched and every single person seems to have a different solution to the problem. Some work for one person but not the other. All i want to know is how do you Identify whats causing your specific problem?
For example, My window started falling off track every once in a while once it started to get cold this year. It only does it when its cold outside. I heard greasing/lubing the track would help so i did that. Didnt do anything. Hear that a new track would fix it. $20 later is didnt do expletive and now i cant put my window down all the way regaurdless of tempature without it falling off.
Old Jan 11, 2007 | 08:43 AM
B18CivicEH2's Avatar
Default Re: How to identify cause of window falling off track in an EK? (xxsteve803xx)
How to identify the culprit = Take door panel off and observe...i suggest you look at the little rollers on the regulator...
Old Jan 11, 2007 | 08:51 AM
Hybrid-Fusion's Avatar
Default Re: How to identify cause of window falling off track in an EK? (B18CivicEg)
Usually the guides can use a little lube and the bolts that hold the window on the track below can use to be tightened. Use Lock Tite!
Old Jan 11, 2007 | 09:03 AM
JDM_teh_WIN!!'s Avatar
Default Re: How to identify cause of window falling off track in an EK? (Hybrid-Fusion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid-Fusion &raquo;</TD></TR><TR><TD CLASS="quote">Usually the guides can use a little lube and the bolts that hold the window on the track below can use to be tightened. Use Lock Tite! </TD></TR></TABLE>
What he said
Old Jan 11, 2007 | 09:08 AM
Ricey McRicerton's Avatar
Default Re: How to identify cause of window falling off track in an EK? (JDM_teh_WIN!!)
Usually it's a bent regulator and unlubed tracks.
Old Jan 11, 2007 | 09:15 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: How to identify cause of window falling off track in an EK? (Ricey McRicerton)
i had the same issue with my ek a few weeks ago. after lubing the track using silicone spray, it would still jump off the track. there is an adjustment on the bottom of the track. i moved it over, and no problems since.
MIKE_HWD
Sep 24, 2007 05:17 PM
bleedblue94
16
Nov 25, 2006 09:04 PM
murmur9
12
Nov 20, 2004 09:27 PM
gulf imports
May 25, 2004 09:06 AM
f1uxx
Mar 9, 2003 09:44 PM
