Excessive Blue Smoke
Old Jan 10, 2007 | 08:02 PM
j-bird20's Avatar
Default Excessive Blue Smoke
i went tuning today and towards the end of the tune...the car started blowing out whiteish blue smoke from motor and exhaust..i pulled the car over and poped the hood and the oil dipstick poped out leting all the oil out...the motor kinda sorta runs its mostly just constant smoke and bogging....did i blow the headgasket or a piston/ring....let me know thanks
Old Jan 10, 2007 | 08:39 PM
street_accord94's Avatar
make sure you have enough oil in the engine, then do a proper compression test and come back with the results
Old Jan 10, 2007 | 09:07 PM
NJ VTECpowered's Avatar
Default Re: (street_accord94)
sounds like your burning oil
Old Jan 10, 2007 | 09:29 PM
Laskowski's Avatar
Default Re: Excessive Blue Smoke (j-bird20)
only a compression test will tell, white smoke usually means blown headgasket though... maybe you have a bit of both how many miles on the motor?
Old Jan 10, 2007 | 10:22 PM
pos_cd5's Avatar
Default Re: Excessive Blue Smoke (Laskowski)
blue smoke means your burning oil. your dip stick poping out means there is excessive pressure build up in your crank case, which leads me to believe your PCV valve is stuck closed. check the PCV valve, im pretty sure that will solve your problem
Old Jan 11, 2007 | 02:55 PM
j-bird20's Avatar
Default Re: Excessive Blue Smoke (pos_cd5)
im going to check compression tomorrow.....where is the PCV located on a 2001 accord 4cyl(f23A)...thanks guys
Old Jan 11, 2007 | 04:57 PM
H22isnotabigblock's Avatar
id have to say head gasket or pcv
either the PCV is not allowing crankcase pressure to be vented
or the headgasket is toast and is pounding the compression that is being lost from the cylinders into the crankcase, but then it would also show up in the cooling system, id check the PCV first, since it is both cheap and easy
Old Jan 11, 2007 | 05:59 PM
pos_cd5's Avatar
Default Re: Excessive Blue Smoke (H22isnotabigblock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22isnotabigblock &raquo;</TD></TR><TR><TD CLASS="quote">id have to say head gasket or pcv
bad headgasket wouldnt leak compression into the crank case, only rings would do that.
battosai
Aug 29, 2014 07:46 AM
tommy.
11
Mar 26, 2006 10:49 AM
tianporn
10
Jul 20, 2004 11:24 AM
roninb18
Feb 28, 2003 10:19 AM
redteg1
Sep 19, 2002 04:29 PM
