all motor ls vtec vs. all motor b20 vtec
ok i have a 91 ls motor and i am going for the build i have nice stock block and i am trying to achieve right around 230hp give or take i am thinking right around 12.5:1 - 13:1 compression and i am using a worked gsr head ported and polished with a 3 angle valve job. i have a couple ?'s.
1. how much compression can i put on a stock sleeved block with pump gas vs. a sleeved ls block to a 2.0L?
2. which will be more reailable.
3. is the power i am going for achieveable?
4. and is it going to be worth y time to sleave my block to a 2.0 or should i go higher.
i am getting a set of custom Aries pistons so that is not going to be a problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastcrx89 »</TD></TR><TR><TD CLASS="quote">ok i have a 91 ls motor and i am going for the build i have nice stock block and i am trying to achieve right around 230hp give or take i am thinking right around 12.5:1 - 13:1 compression and i am using a worked gsr head ported and polished with a 3 angle valve job. i have a couple ?'s.
1 and 2 would depend on the tune. 3 would would also depend on the tune and parts used. 4, well you'll have an easier time hitting your hp goal with more displacement.
</TD></TR></TABLE>1 and 2 would depend on the tune. 3 would would also depend on the tune and parts used. 4, well you'll have an easier time hitting your hp goal with more displacement.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood »</TD></TR><TR><TD CLASS="quote">
1 and 2 would depend on the tune. 3 would would also depend on the tune and parts used. 4, well you'll have an easier time hitting your hp goal with more displacement.</TD></TR></TABLE>
These may or may not give you a hand in cam selection and piston selection (if you haven't chosen any yet) but are still a good read regardless.
http://www.team-integra.net/se...D=472
http://www.team-integra.net/se...D=233
You don't need compression that high to make that much power. 11.5 is all you really need. Contrary to popular belief, the power is in the head, not the block. Having a nicely worked GSR head is a great starting point. You'll definitely need at least an 84mm bore though. You're not going to get much higher than 2.0 unless you stroke it as well but the 87.2/89mm cranks are really ideal for drag racing as they produce peak power later in the curve.
</TD></TR></TABLE>You don't need compression that high to make that much power. 11.5 is all you really need. Contrary to popular belief, the power is in the head, not the block. Having a nicely worked GSR head is a great starting point. You'll definitely need at least an 84mm bore though. You're not going to get much higher than 2.0 unless you stroke it as well but the 87.2/89mm cranks are really ideal for drag racing as they produce peak power later in the curve.
yes that makes since i have now gottin a ls block whit oversize p30's and i am goin to put my head on that with omni power internals and skunk2 stage 2 pro series cams and tune the expletive out of it. hoping i will hit right around 200 to the wheels. anyone one have any comment to give to get there or improve that havent bought the head package yet so looking for some good input.
thanks ,
ricky
thanks ,
ricky
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poppabuff23 »</TD></TR><TR><TD CLASS="quote">i got a 2.0L ls/vtec and with the stock head im at 202whp and 157wtq. i getting s2 pro2's, bigger td and im. im hoping for 220whp</TD></TR></TABLE>
You need some headwork. headwork and header are the two most deciding factors on power output.
a good port job. cams are equally important as they compliment each other. You can get more out of whatever cams you choose with matching headwork and vice versa. Add a good header and you'll be amazed. You an probably gain 50-60whp from some good cams/header/headwork.
my head isnt completey stock but the things i did didnt do as much as i wanted. my head has s2s1 cams, valve springs,header, and intake. but with those mods it made it alittle bit faster but not as much as i was expecting. but after i put that built 2.0L LS block in i was happy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poppabuff23 »</TD></TR><TR><TD CLASS="quote">my head isnt completey stock but the things i did didnt do as much as i wanted. my head has s2s1 cams, valve springs,header, and intake. but with those mods it made it alittle bit faster but not as much as i was expecting. but after i put that built 2.0L LS block in i was happy.</TD></TR></TABLE>
The S2S1's are choking your 2.0. What header are you using?
shitty DC 4-1 header 2.25inch. I know what i need just need money. when the track opens im gonna buy drag radials and hoping for low to mid 13's. what do you guys think. does anybody know someone that has done both the itr oem lsd and final gear swap on b16 tranny and if so is it worth the money
JDM00SI
Nov 1, 2005 04:50 PM
