tial 38mm wastegate spring color - psi ??
Old Jan 10, 2007 | 05:42 PM
Turbo_y8's Avatar
Default tial 38mm wastegate spring color - psi ??
i have 2 38mm wastegate springs, i have a blue spring and black. anyone know the psi on those?
Old Jan 10, 2007 | 05:57 PM
genocide43110's Avatar
Default Re: tial 38mm wastegate spring color - psi ?? (Turbo_y8)
SPRING RATE GUIDE
38mm/41mm Wastegate
0.25 Bar - 3.63 psi - Small Yellow
0.4 Bar - 5.80 psi - Small Red
0.5 Bar - 7.25 psi - Small Green
0.6 Bar - 8.70 psi - Small Blue
0.7 Bar - 10.15 psi - Large Yellow
0.8 Bar - 11.60 psi - Large Red
0.9 Bar - 13.05 psi - Large Green
1.0 Bar - 14.50 psi - Large Blue
I don't see a black so I have no idea.
Modified by genocide43110 at 7:26 PM 1/10/2007
Old Jan 10, 2007 | 05:58 PM
Treblarefils's Avatar
http://www.tialsport.com
http://tialsport.com/documents/w3_tial_38_sp.pdf
Old Jun 7, 2007 | 05:03 PM
SinglecamMitch's Avatar
Default Re: tial 38mm wastegate spring color - psi ?? (Treblarefils)
Back from the dead... What psi is the black spring?
Old Jun 7, 2007 | 06:48 PM
TiAL's Avatar
Default Re: tial 38mm wastegate spring color - psi ?? (SinglecamMitch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SinglecamMitch &raquo;</TD></TR><TR><TD CLASS="quote">Back from the dead... What psi is the black spring? </TD></TR></TABLE>
it's a BOV spring, not for wastegate use
Old Jun 8, 2007 | 09:15 AM
Default Re: tial 38mm wastegate spring color - psi ?? (TiAL)
well it was in a wastegate... anybody got a clue on what psi this guy would run?? seems pretty stiff
Old Jun 8, 2007 | 10:45 AM
PrecisionH23a's Avatar
If it's not in there... it's not a tial part.
Old Jun 8, 2007 | 11:24 AM
TiAL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SinglecamMitch &raquo;</TD></TR><TR><TD CLASS="quote">well it was in a wastegate... anybody got a clue on what psi this guy would run?? seems pretty stiff</TD></TR></TABLE>
it's not a tial spring, you can't use a BOV spring in a wastegate
Old Jun 8, 2007 | 02:27 PM
i understand that but whos to say it wont work... its the same size as a small spring so i might actually push some psi that i could use... jw
2LiterTurboSeR
Jun 4, 2006 08:43 PM
jure
May 6, 2004 02:32 PM
Mikes01GSR
Apr 16, 2004 12:08 PM
GettaluvR
Dec 13, 2002 05:39 AM
