N/A Project, Injector Upgrade?
Mods:
CAI
70mm TB
Euro-R Manifold
Type-S Cams
SK2 ADJ cam gears
T1R Header (2.36'' collector)
Test Pipe (2.25'')
Thermal EX. (2.25")
I have a 2001 prelude with a H22a4. Will I need to upgrade my injectors?
CAI
70mm TB
Euro-R Manifold
Type-S Cams
SK2 ADJ cam gears
Test Pipe (2.25'')
Thermal EX. (2.25")
as much as i would love to tell you that your 290cc's will be cool. You will be on the edge of needing to upgrade depending on the fueling that is going to be required to achieve at certain target afr. If i were in your shoes, i would upgrade to the OBDI prelude injectors which are 345cc but require OBDI clips and a resistor.
If you need a resistor and OBDI clips, i can cater to your needs in that department.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B.Rabbit »</TD></TR><TR><TD CLASS="quote">as much as i would love to tell you that your 290cc's will be cool. You will be on the edge of needing to upgrade depending on the fueling that is going to be required to achieve at certain target afr. If i were in your shoes, i would upgrade to the OBDI prelude injectors which are 345cc but require OBDI clips and a resistor.
If you need a resistor and OBDI clips, i can cater to your needs in that department.</TD></TR></TABLE>
Nice plug!
Nice plug!
Here is a list of my mods in there entirety.
1.H22a Head Swap (Honda Cyl. Head Gasket Kit)
a. Skunk2 Springs and Ti Retainers
b. Type-S Cams
c. Skunk2 Cam gears
d. BDL Cam Plug
e. Euro-R IM
f. BDL 70mm TB
g. RC 440cc Saturated Injectors
2. Maintenance
a. New Timing Belt
b. New Water Pump+gasket
c. New Fuel Filter
I knew the outline format i learned in english class would come in handy.
b. Type-S Cams
c. Skunk2 Cam gears
d. BDL Cam Plug
e. Euro-R IM
f. BDL 70mm TB
2. Maintenance
a. New Timing Belt
c. New Fuel Filter
290s could probably be made to run that, barely. That would be my experience, at any rate. Upgrading is not a bad idea.
What kind of engine management are you using/going to be using?
Hondata S200 on a P28 ECU. Getting it tuned at tempest racing by Joe Simpson. Awesome Tuner and Awesome Guy
http://www.joesimpsonracing.com
