Honda S2000 Honda S2000
Engine Knocking at startup
Old May 14, 2002 | 05:29 PM
Synapse's Avatar
Default Engine Knocking at startup
Is anyone else experiencing knocking when they startup their S2K? Kinda scary, since this usually means oil in the cylinder.
Old May 15, 2002 | 10:26 PM
Synapse's Avatar
Default Re: Engine Knocking at startup (Synapse)
Checked the plugs, some signs of detonation, typical crappy 91 Cali octane, probably more around 88.
Anyways, there was no oil on the combustion chamber, but 1 and 4 had lotsa oil on the threads.
Any thoughts? Is the valve cover just not torqued enough?
Old May 18, 2002 | 08:10 AM
Wmiller563's Avatar
I THINK YOU CAN EXPERIENCE KNOCKING WHEN THE TIMEING IS OFF. NOT TO SURE THOUGH.
[Modified by Wmiller563, 5:10 PM 5/18/2002]
Old May 18, 2002 | 05:49 PM
Blue-Civic-Hybrid's Avatar
Loved
Take that car to the dealer ASAP!!!
Old May 18, 2002 | 11:26 PM
FULLTHROTTLE's Avatar
Default Re: Engine Knocking at startup (Blue-Civic-Hybrid)
If it knocks for just a second at cold startup it may just be the oil pressure getting to the valve train. If it knocks for a little longer like for 10-30 seconds it could be piston slap, or worse yet piston skirt damage from oil starvation. These little guys can use up to a quart of oil every 1000 miles and if not checked can eat up piston skirts. Either way it needs to see a Honda Technician. For future reference, low octane fuel will only cause knock under load and or under extreme engine temps. (that is if the fuel system is working correctly). Hope this helped.
Old May 19, 2002 | 06:54 AM
Synapse's Avatar
Default Re: Engine Knocking at startup (FULLTHROTTLE)
What every S2K owner needs in their car at all times
After my last post about my car knocking @ startup I decided to just change the plugs altogether.
I changed them over the to the Denso Iridiums in the heat range of 8 (I don't think Heat range really matters unless you're turbo or lotsa NA BMEP). The car idles better, revs smoother, sounds more like it should.
But because of crappy 91 octane my car was always pinging (detonating), I couldn't even relax and listen to the radio because I was afraid that I would grenade the motor.
Picked up some NOS octane boost and the car sounds and runs the way it should. This is a must have in the trunk. And good for 20 gallons, so 2 fill-ups for about 8 bucks. It sucks that we have to do this, but with 11:1 CR no real alternative is there.
Old Sep 6, 2016 | 09:22 AM
CLhater's Avatar
I know this is 7 years after the last post on the subject but my 2.3 CL does the same thing (it has 252,000 on it but I replaced the oil pump while doing the timing belt & water pump figuring it might be the culprit). After doing this to no avail, and until I have time to pull the oil pan and plastic-gauge the bearings, I decided to try something to nurse it. I bought a non-chip key and I crank the engine until the oil light goes out (usually about 15-20 seconds). Then I put my chip key in and start it. No knocking at all now at cold startup. And I still run it to 5,000 rpm sometimes and it's relatively quiet. Shame no-one has come up with a definitive solution to the problem but I really believe it's a rod bearing. After a month or so of doing this I decided to change from regular synthetic to Shell Rotella synthetic 5 w 40 (yes it's diesel oil). Now I only have to crank it for 10 seconds in the morning or after it sits for a couple hours. Hope the non-chip key idea helps someone.
Old Oct 24, 2016 | 09:41 AM
PhillipM's Avatar
Sure it's not the common thrust washer problem?
Old Oct 25, 2016 | 04:58 PM
CLhater's Avatar
Now that's what i was hoping for, someone to tell me what it could be. I didn't know there was a common thrust washer problem. I'll check it out first chance i get.
Thank you very much!
Old Oct 25, 2016 | 05:00 PM
PhillipM's Avatar
Worth a look, problem is if it's picked up there'll be a burr on the crank you'll have to get rid of before fitting a new pair.
therhett17
Nov 19, 2014 03:04 PM
purplerain11
Jul 6, 2012 06:42 PM
Ryan_v
Jul 14, 2009 03:41 PM
Takumi Fujiwara
Feb 23, 2006 08:18 AM
CroSi
Aug 14, 2003 04:32 PM
