threaded hole on turbo
Old May 14, 2002 | 04:33 PM
vtecsiqt's Avatar
Default threaded hole on turbo
I need to know if this is true...I was told that the threaded hole on the compressor, of the turbonetics turbo, is to be plugged if you are using an intercooler. Because if you didn't have an intercooler you would use this for a vaccum source for the wastegate, instead of one from the intake manifold... If someone could verify this, and tell me how they plugged it that would be great....
Old May 15, 2002 | 06:46 AM
DragII's Avatar
25 Year Member
Default Re: threaded hole on turbo (vtecsiqt)
buy a 1/4" brass plug at home depot.
Old May 15, 2002 | 06:55 AM
PrecisionH23a's Avatar
if i understood what you wrote correctly, then what you were told was not true. this threaded hole is used for a brass nipple with a vacuum line that will connect to another brass fitting on the side of your wastegate, with or without an intercooler.
ThE HeLLRaZoR
Oct 12, 2012 11:31 AM
b18_integra
Feb 18, 2008 04:42 PM
vladd
Nov 9, 2006 06:56 PM
Blindstuff
Feb 15, 2004 12:49 PM
phase12gsr
Oct 28, 2002 08:00 PM
