tach mounting question
Old May 14, 2002 | 04:19 PM
LiLn81224's Avatar
Default tach mounting question
i want do mount a tach in my 96 hatch, because it doesnt have one, even tho it is an automatic, i still wanna know wut rpm im runnin at, so my question is, wher is the easiest place to mount one? and how easy and how much will it cost?? all i want is a small one, just something that will get the job done. I think i saw some at autozone for like 50 bucks, so i was just wonderin wut i need to do to mount it..thanks
Old May 14, 2002 | 05:45 PM
Mikes94's Avatar
Default Re: tach mounting question (LiLn81224)
I had an aftermarket tach on my old civic ('85). It was a 3-3.5 inch pod type that bolts onto your dash/cluster or whatever. I didnt want to drill holes in my dash so I used 3 suction-cups to hang it from the windscreen (between the pillar and gauge cluster hump). It actually looked quite mean and surprisingly didnt fall off ... even when pushing hard through corners!!
I've also seen smaller tachs mounted on the top of the steering column.
Good-luck
Mike
Scantron
Jan 24, 2006 09:08 AM
sniperslayer
14
Oct 3, 2004 03:58 PM
Setsuna F Seiei
May 20, 2004 10:32 AM
kent
Apr 19, 2003 09:47 AM
underpressure02
16
Dec 5, 2002 11:48 AM
