what plug goes into this eacv ?
Old Jan 8, 2007 | 04:56 PM
nk2k2's Avatar
Default what plug goes into this eacv ?
well unfortunatly its another dpfi to mpfi question. the eacv on my manifold is located on the back and it has a white sensor on it and i was wondering what plugs/wires do i take off the dpfi harness so i can connect it. Ohh btw, i do have a Si harness laying around to grab plugs off. it is the yellow circled item in the picture below.
Old Jan 8, 2007 | 05:12 PM
janz3n's Avatar
Default Re: what plug goes into this eacv ? (4g4d)
you use the one that was connected to your dpfi eacv.. no need to swap plugs. just need to lengthen the wire so it reaches.
Old Jan 9, 2007 | 01:31 PM
nk2k2's Avatar
Default Re: what plug goes into this eacv ? (janz3n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n &raquo;</TD></TR><TR><TD CLASS="quote">you use the one that was connected to your dpfi eacv.. no need to swap plugs. just need to lengthen the wire so it reaches.</TD></TR></TABLE>
what color is the plug? green or white?
Old Jan 9, 2007 | 03:58 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g4d &raquo;</TD></TR><TR><TD CLASS="quote">
what color is the plug? green or white? </TD></TR></TABLE>
I think the green one was for the secondary fuel injector.
If your not sure, just plug one in, if it doesn't work, switch. I had a couple ones mixed up when I did my swap, when the CEL popped up, I ran the code, figured out which plug was fucked up, and switched it.
Old Jan 9, 2007 | 04:22 PM
ChickenH's Avatar
Default Re: what plug goes into this eacv ? (Tippyman)
if you plug in the tps wiring connector( i think? maybe it was the map? ) it rams the iac gear thing all the way over and sometimes ruins them. make sure its the right one before you just plug one in.
Old Jan 9, 2007 | 04:49 PM
89hatcher's Avatar
its the green plug. the white plugs are for the intake air temperature and for the purge.
Old Jan 9, 2007 | 04:58 PM
driftdas2000's Avatar
Default Re: (89hatcher)
blk/yel and blue i beleive are wire colors
xprometheusx
Jun 9, 2014 08:06 AM
bigcheese42
Mar 23, 2006 04:08 AM
Luserkid
20
Dec 9, 2004 10:16 PM
BLUE EH3
11
Aug 2, 2004 04:52 AM
4crx4me
May 18, 2004 08:17 AM
