Where does this plug go?
Old Mar 19, 2006 | 04:14 PM
bigcheese42's Avatar
Default Where does this plug go?
It comes off the wire harness by the injector plugs. It has a white wire with a red stripe and a blue wire with a red stripe. I just put in a new block and this is the last thing. I must be blind.
Old Mar 19, 2006 | 04:44 PM
nholmes's Avatar
Default Re: Where does this plug go? (bigcheese42)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigcheese42 &raquo;</TD></TR><TR><TD CLASS="quote">I must be blind.</TD></TR></TABLE>
Me too. Pictures would help.
Old Mar 21, 2006 | 08:39 PM
Default Re: Where does this plug go? (nholmes)
Sorry, no digi camera. Could this be the ckf sensor?
Old Mar 21, 2006 | 08:44 PM
Mythias's Avatar
To the kuhneutson valve.
Old Mar 21, 2006 | 10:01 PM
citrus3000psi's Avatar
I think theres a plug off the injector harness that plugs directly into the IM. Im not sure I really remember but I think it does.
I would look but its cold outside. God I hate Indiana weather.
-Dan
Old Mar 22, 2006 | 01:56 AM
Circuit Star-29's Avatar
Default Re: Where does this plug go? (citrus3000psi)
Chassis? Harness? Motor?
Old Mar 22, 2006 | 06:42 AM
citrus - no, it's not the one that goes to the manifold. thanks though.
circuit - It comes off the main engine harness.
Old Mar 22, 2006 | 06:58 AM
RTW DC2R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigcheese42 &raquo;</TD></TR><TR><TD CLASS="quote">Sorry, no digi camera. Could this be the ckf sensor? </TD></TR></TABLE>
crank fluctuation sensor is down by the crank pulley, behind the timing belt cover.
sounds like it could either lead to the back of the block, or its just one of the sensors on the IM, TB, or IACV I dont know the wire colors off hand.
Old Mar 22, 2006 | 07:09 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: Where does this plug go? (RTW DC2R)
The only plug that I can remember that comes off by the injectors is the IAT which plugs direclty into the IM. Is it a circular plug? expletive it, try and start it, if you have a code, check it, problem solved.
Old Mar 23, 2006 | 01:12 AM
Default Re: Where does this plug go? (walker111)
grab a helms or something...without pix, its useless to ask us...
Under the circumstances.
Old Mar 23, 2006 | 03:36 AM
freakie's Avatar
Default Re: Where does this plug go? (Circuit Star-29)
will be the IAT sensor that plgus into runner 3 on the itr manifold
Old Mar 23, 2006 | 04:08 AM
Black R's Avatar
25 Year Member
iat, tps, or map sensor?
MattsGreenEG
Sep 26, 2007 08:01 AM
nk2k2
Jan 9, 2007 04:58 PM
.doeboyfresh.
Aug 1, 2006 12:23 PM
eg6cvchatch
Jun 8, 2005 05:28 AM
4crx4me
May 18, 2004 08:17 AM
