Lets play "where do these plugs go"?
Ok help me out, finishing up this H22 swap and i need to know where the hell these plugs go. Im hoping there nothing because theres no real place to put them.
Grey 2P plug (this is coming from the firewall harness)
Same plug, wire colors red/green & blk/yellow
Now this is something funny, i got <FONT SIZE="2">3</FONT> green plugs, all 2P different colors
First one, white/green & Blk
Second one: Brown/blk & blue
Number 3: Green & Blk
TIA!
Modified by Luserkid at 4:59 PM 12/9/2004
TIA!
* B A N N E D *
1 Post
Re: Lets play "where do these plugs go"? (Luserkid)
if you told us more info, maybe we could help.
Like the car this H22 is going into? So I can know the wiring harness and check my helms manual.
Re: Lets play "where do these plugs go"? (Redline96LX)
The wiring harness is from an H22.
This is going into an accord I know i know i should have posted this in the Accord forum or even the Prelude but come on, but we all know that the EG forum is the fastest around. Hopefully i could get help. But if need be and needs to move then so be it.
i checked the helm manual for 92-96 prelude and still can't find those plug. where are those plug located or close to? maybe i can help you id it.
Re: Lets play "where do these plugs go"? (2lua)
Dont you have a meter? Just trace that back to the ecu checking continuity if your unsure. P13 pinout:
Contact Color Description
A1 brn Injector #1
A2 yel Injector #4
A3 red1 Injector #2
A4 grn/yel VTEC Solenoid Valve
A5 blu Injector #3
A6 or/wht HO2S heater coil
A7 grn/blk1 PGM-FI Main Relay coil
A8 grn/blk2 Shorted to A7
A9 blk/blu IAC Valve
A10 - -
A11 red2 EGR Control Solenoid
A12 blu/red Condenser Fan Relay
A13 blu/wht MIL
A14 - -
A15 red/blu A/C Clutch Relay
A16 wht/grn Alternator
A17 pink IAB Solenoid Valve
A18 - -
A19 wht Intake Control Solenoid Valve
A20 red/grn EVAP Purge Control Solenoid
A21 yel/grn1 ICM
A22 yel/grn2 Shorted to A21
A23 blk1 GND
A24 blk2 GND
A25 yel/blk PGM-FI Main Relay (power)
A26 blk/red VTEC Pressure Switch (GND)
B1 yel/blk PGM-FI Main Relay (power)
B2 brn/blk GND
B3 - -
B4 - -
B5 blu/blk To A/C Switch
B6 - -
B7 - -
B8 red/grn PSP Switch
B9 blu/red Starter Cut Relay
B10 orn2 VSS
B11 orn3 CYP
B12 wht CYP
B13 orn/blu TDC
B14 wht/blu TDC
B15 blu/grn CKP
B16 blu/yel CKP
D1 wht/yel Battery
D2 grn/wht1 Brake Switch
D3 red/blu KS
D4 brn/wht SCS
D5 - -
D6 lt blu or lt grn VTEC Pressure Switch
D7 lt grn/red Data Link Connector
D8 - -
D9 wht/red ALT
D10 grn/blk ELD
D11 red/blk TP Sensor
D12 wht/blk EGR Valve Lift Sensor
D13 yel/blu ECT Sensor
D14 wht HO2S Sense
D15 red/yel IAT Sensor
D16 - -
D17 wht/blu MAP Sensor
D18 - -
D19 red/wht EGR Valve Lift Sensor
D20 yel/wht TP Sensor
D21 blu/wht MAP Sensor
D22 grn/wht2 TP Sensor
A1 brn Injector #1
A2 yel Injector #4
A3 red1 Injector #2
A5 blu Injector #3
A10 - -
A13 blu/wht MIL
A14 - -
A18 - -
A21 yel/grn1 ICM
A23 blk1 GND
A24 blk2 GND
B2 brn/blk GND
B3 - -
B4 - -
B6 - -
B7 - -
B10 orn2 VSS
B11 orn3 CYP
B12 wht CYP
B13 orn/blu TDC
B14 wht/blu TDC
B15 blu/grn CKP
B16 blu/yel CKP
D1 wht/yel Battery
D3 red/blu KS
D4 brn/wht SCS
D5 - -
D8 - -
D9 wht/red ALT
D10 grn/blk ELD
D14 wht HO2S Sense
D16 - -
D18 - -
Re: Lets play "where do these plugs go"? (95excoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua »</TD></TR><TR><TD CLASS="quote">i checked the helm manual for 92-96 prelude and still can't find those plug. where are those plug located or close to? maybe i can help you id it.</TD></TR></TABLE>
All the green plugs are near the thremostat, VTEC, Oil Pressure, etc. Area of the engine, and that grey plug is coming from the pass. side shock tower harness (the one that goes into the firewall).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95excoupe »</TD></TR><TR><TD CLASS="quote">Dont you have a meter? Just trace that back to the ecu checking continuity if your unsure. P13 pinout:
Ill try that tomorrow when i have light.
Re: Lets play "where do these plugs go"? (eg6T)
Can we get off my hands for a min here, sheesh.
Nah its not for the speed sensor because the speed sensor was a 3P
Re: Lets play "where do these plugs go"? (94_HATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_HATCH »</TD></TR><TR><TD CLASS="quote">why ones do you still need?</TD></TR></TABLE>
I need to know where all of them go to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Same plug, wire colors red/green & blk/yellow</TD></TR></TABLE>
EGR control solenoid Valve
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">First one, white/green & Blk</TD></TR></TABLE>
See reply below
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Second one: Brown/blk & blue</TD></TR></TABLE>
This maybe VTP. Get me the year and engine the harness goes to, JDM or USDM (you are unclear in your posts) and I will tell you what everything is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Number 3: Green & Blk</TD></TR></TABLE>
PS load detector. The sensor is on the PS pressure line by the steering rack.
This is for a 94 accord, get me the year (if not 94) and I will get a diagram like this.
See reply below
skidmarkroyalty
05-07-2014 07:26 PM
hotimportcrx
01-31-2006 07:42 AM
fire7882
05-25-2002 04:35 AM
