ls/vtec
How much hp u think a stock ls/vtec will make?
b18a block b16a1 head
stock b18a pistons
How much can i mill a b16a head?
What can i do to up the comp with out putting pistons in?
stock b18a pistons
My b16 head is milled .020. It will make the CR ~10.1:1. I will be putting my setup together this coming weekend.
If you would like to see my setup, go here https://honda-tech.com/zerothread?id=185733
I have no Idea how much power it will make though.
With ls pistons, your compression will be 9.5 before you mill the head. With b16 pistons, 11.3. All you have to do is put the pistons on the ls rods.
If your all motor you need the b16 pistons or your enigne is weak.
