Need some help figuring out what this tranny is from...
I have a d series tranny, and I'm not exactly sure what it came off of. I got in a trade and I know its fine since a freind was using it. My guess is that it is from a y7 motor, but I want to make sure. The code on it is: s20-1408669
your help is appreciated!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G3NR8 »</TD></TR><TR><TD CLASS="quote">I have a d series tranny, and I'm not exactly sure what it came off of. I got in a trade and I know its fine since a freind was using it. My guess is that it is from a y7 motor, but I want to make sure. The code on it is: s20-1408669
http://www.crxmpg.com/transmission.html
92-95 civic above link should tell you anything else you need to know?
hope this helps
richard
</TD></TR></TABLE>http://www.crxmpg.com/transmission.html
hope this helps
richard
Under the trans by the axel i believe there should be a nooo??? Something find out which one it is then you find out the most important thing
Is it a golden vtec trans or a extra long geared gas saver!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">If you have a problem with my posts, don't read them.
It's as ******* simple as that. Simply don't, *******, read 'em. Not rocket science. So other than that, quit bitching & learn to ******* deal with it. I'm sorry you people suck at life too much that you're not able to skip a post in an INTERNET thread - though, obviously you are indeed unable to do so, which almost makes me feel bad...not quite...but almost. Bitches.
this is about the best quote i have read so far on honda tec if it was not such a cheap shot i would copy and past it too LOL
Thanks for the help. That link didn't provide much insight into what tranny I have on my hands. Good info though
I'll have to look at it again to see if there are any more numbers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G3NR8 »</TD></TR><TR><TD CLASS="quote">Thanks for the help. That link didn't provide much insight into what tranny I have on my hands. Good info though
I'll have to look at it again to see if there are any more numbers. </TD></TR></TABLE>
when you say you want to know what kind of tranny you have then check the numbers by the axle
really small should be n000b or a i think it is that will tell you weather it is vtec trans or none vtec trans
if it was not too cold outside i would check mine
SoOHiGH
11
May 4, 2005 11:20 PM
NightHawkC5
Oct 1, 2003 04:24 AM
