piston question
Old Jan 5, 2007 | 12:34 PM
MugenManR's Avatar
Default piston question
i have a d seris and i did a mini me swap, now my compression in a 10:1. i wana turbo it but thats a bit high of a compression so i was ether going to swap the pistions or get a thicker head gasket. any ideas personal experinces would be great. thank you ahead of time.
Old Jan 5, 2007 | 12:50 PM
doood's Avatar
been there done that
Default Re: piston question (MugenManR)
10:1 is not too high if you run the right octane and have a good tune. but yes a thicker headgasket will help lower it.
Old Jan 5, 2007 | 12:57 PM
MugenManR's Avatar
Default Re: piston question (doood)
i rather be safe then sorry, who sells thicker head gaskets.
Old Jan 5, 2007 | 01:22 PM
sal's Avatar
sal
Cometic
Old Jan 5, 2007 | 01:24 PM
jtchinoy's Avatar
go to ebay and buy a namebrand one
Old Jan 5, 2007 | 01:28 PM
MugenManR's Avatar
Default Re: piston question (sal)
about how much will it cost. and do i have to prep the head and block for it. and whie the head is off waht other lil things can i do to increase stablily and a bit of performance
Old Jan 5, 2007 | 01:41 PM
sal's Avatar
sal
Usually around $80-$100. Since the head is off it wont hurt to get it milled to ensure that its perfectly flat to get the best seal. Then again that will bring your compression up slightly so you might not want to.
Old Jan 5, 2007 | 02:25 PM
no_rice_please's Avatar
just get it tuned right and it should be fine
Old Jan 5, 2007 | 02:28 PM
EJgsr's Avatar
Default Re: (no_rice_please)
10:1 is fine to boost...
Old Jan 5, 2007 | 07:16 PM
MugenManR's Avatar
Default Re: (USDMej1)
so 10:1 is good to run 6-7lbs of boost. on stock eveything.
Old Jan 6, 2007 | 10:05 AM
sal's Avatar
sal
Default Re: (MugenManR)
If its tuned, yes thats fine.
Old Jan 6, 2007 | 10:08 PM
MugenManR's Avatar
Default Re: (sal)
ok thank you all.
Old Jan 8, 2007 | 10:59 AM
EJgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenManR &raquo;</TD></TR><TR><TD CLASS="quote">so 10:1 is good to run 6-7lbs of boost. on stock eveything. </TD></TR></TABLE>
you can run ALOT higher boost than that... if it was built..
Old Jan 8, 2007 | 01:40 PM
MugenManR's Avatar
i could do a mild buid. any sugestion on what i could do.
Old Jan 9, 2007 | 10:22 AM
sal's Avatar
sal
Forged pistons and rods would help out quite a bit.
Old Jan 9, 2007 | 11:46 AM
MugenManR's Avatar
Default Re: (sal)
how much would that go for?
BLU CIVIC
11
Nov 3, 2009 05:35 AM
kc4door
Jan 22, 2006 05:47 PM
fredtoast
Feb 16, 2004 10:25 AM
fastludeh22
Oct 16, 2003 10:45 PM
StinkyTofu
Jan 9, 2002 11:12 AM
