difference in PR vitaras and OEM ones
Old Jan 5, 2007 | 10:49 AM
claytonsmith's Avatar
Default difference in PR vitaras and OEM ones
does anyone know if there is a difference in the vitaras coming from puerto rico and the ones that are available from the stealership? i have a set of.5mm overbore vitaras ( that is apparently a size taht is only available from the dealership) and im wondering if there is a difference in the strength of these i have and the ones that people like FJT are selling out of PR
ive had a set of the PR ones before and there is an obvious appearance difference. the oem ones arent coated and the oil holes in the pistons are different
anyone know if its a different alloy?
thanks in advance
Old Jan 5, 2007 | 08:50 PM
Default Re: difference in PR vitaras and OEM ones (claytonsmith)
no one? alright.. awesome?
Old Jan 5, 2007 | 10:02 PM
rextec's Avatar
they are a different heat treated alloy. why dont you just ask fjt???
Old Jan 7, 2007 | 01:28 PM
Default Re: (rextec)
ive asked fjt.. no response...
anyone know for sure/able to verify that they are a different alloy?
Old Jan 7, 2007 | 04:03 PM
fjt's Avatar
fjt
Yes there is a difference. The OEM from the dealership are not made from the same material..and dont have the coating that the Y.C.P. ones have..
For once the replacement piston is way better than the OEM...OEM ones wont hold the same power as the Y.C.P. ones.
Northernlightz
Acura TSX
Aug 22, 2018 04:22 PM
Ek909
12
Feb 6, 2011 09:38 PM
buymesomedunks
Feb 7, 2010 10:34 PM
shurick
Mar 24, 2006 11:59 PM
ANDREW D
Mar 23, 2005 07:09 PM
