T25 homemade setup car is breaking up
Old Jan 4, 2007 | 09:11 PM
Frost7177's Avatar
Default T25 homemade setup car is breaking up
Its a homemade turbo setup with a t25 turbo. side mount and inercooler piping oviously. Ive been searching around for injectors off of Dsm's Should I go wit the Blue top manual style 450's or the Auto 390's. Also running a stock fuel pump which im going and buying the high flow 255hf pump tomorrow. The Car sputters and breaks up when starting out but will be fine while holding boost up high unless I mash the pedal. It's on a 97 Honda Civic EX d16y8. Now my other concern is when I put these 2 things parts in the car can I run it off the stock ecu and not getting the spiking or studdering or Will I have to go with a p28 chipped neptune? Thanks sorry for the newb question's just got the car last week and already threw a turbo on it.
Old Jan 4, 2007 | 09:13 PM
dunkd's Avatar
your going to need something to turn down the DSM injectors... V-AFC would be your cheapest route, which it looks like you are going for.
Old Jan 4, 2007 | 09:25 PM
Frost7177's Avatar
Default Re: (dunkd)
Thats what I was thinking also to do that but am I still gonna have to go obd1 or can I just use V-AFC. I used to have a turboed Celic GTS and the stock computer could handle it. Just wonder if its gonna have to be chipped or can I run w injectors n pump and not have to chip the computer and go ob1 and just run the V-AFC?
Old Jan 4, 2007 | 09:26 PM
dunkd's Avatar
u can do it with obd2 and stock computer... the vafc will pickyback the factory ecu.
Old Jan 4, 2007 | 09:59 PM
mtber's Avatar
Default Re: T25 homemade setup car is breaking up (Frost7177)
You need real fuel management...
I recommend you read http://phearable.net/tech/efibeginnerguide.html
Good Luck.
Civic Racer X 7
Nov 2, 2005 11:13 AM
forcefanajd
Mar 21, 2005 09:28 AM
fukes
Jun 1, 2004 04:26 PM
Spoon_Nazi
Sep 4, 2003 08:35 AM
kyle h.
Sep 16, 2002 02:22 PM
